Gigabit or not?
[Closed] Gigabit or not?
I have recently purchased a Gigabit switch for my home network as I have a Gigabit Icybox and apparently a Broadcom NetXteme Gigabit ethernet network card in my PC.
Anyway, its all connected up but network indicator on the PC only says speed is 100MB!
I thought these things would automatically switch up to the higher speed or am I doing something wrong?
Posted : 23/01/2009 4:37 pm
Your onboard card will be 100mb
Posted : 23/01/2009 4:39 pm
What CAT are your ethernet cables?
CAT5 cables won't handle gigabit. You'll need CAT5e or CAT6.
Posted : 23/01/2009 4:51 pm
Surfer - are you missing the bit where he says he has a gigabit card in his machine?
Check the drivers for the card are installed correctly and not using generic windblows drivers?
Posted : 23/01/2009 5:19 pm
A couple of likely things:
- does the cable have all 8 wires connected? You can do 10 or 100Mb half-duplex with 4, but full-duplex (which gigabit needs) takes all 8.
- link speed hard-set in the configuration somewhere. Let it autodetect.
- switch port hard-set (but less likely on home/small-office stuff).
- drivers not right or knackered somehow. Download latest, uninstall the device in device manager, reboot and give it the new drivers.
Posted : 23/01/2009 5:48 pm
Thanks all - replaced cable and now 1Gbps.
Posted : 23/01/2009 6:23 pm
Er yes! Sorry
Posted : 23/01/2009 6:28 pm
Hasn't had any effect on STW though, its still slow!
(I am being sarcastic before anybody suggests that a Gigabit home network has any effect on my Broadband!!)
Posted : 23/01/2009 6:36 pm
