Getting my old turn...
[Closed] Getting my old turntable to work with my amp??
What do I buy to make my old turntable work thru a newer amp. Is it called a phono stage or a pre amp or both or something else??? any recommendations, not too expensive.
Posted : 15/03/2013 4:31 pm
some pre amps have a phono stage - I think you can buy the phono stage separately, no doubt Richer sounds will have something.
Posted : 15/03/2013 4:34 pm
Yeah. You'll need a phono stage.
I don't know if they still do, but on some amps you used to be able to pay to have a phono stage added; my Dad got a Cambridge Audio amp from Richer Sounds and had the phono stage added there & then.
This is the kind of thing you are probably after:
http://www.superfi.co.uk/p-2469-project-phono-box-mk2-turntable-pre-amplifier.aspx?utm_campaign=froogle&utm_medium=organic&utm_source=froogle&gclid=CMSmgaaH_7UCFeXKtAodOX0Acg
Posted : 15/03/2013 4:41 pm
... or you could keep that kidney and get one of these 😀
http://www.ebay.co.uk/itm/NEW-RIAA-Phono-magnetic-cartridge-Turntable-Preamp-PRE-amp-plug-into-AUX-socket-/330836742674?pt=UK_AudioTVElectronics_HomeAudioHiFi_Amplifiers&hash=item4d07681212
You'll probably find one cheaper if you look for a bit longer than I did
Posted : 15/03/2013 4:46 pm
Wind the handle quicker..?
Posted : 15/03/2013 4:48 pm
Richer sounds sell a perfectly decent one for about £20
It's what a got when I realised that the option marked "phono" on my amp wasn't actually a phone stage
Having said that I intend to upgrade to the one Rega do for about £80 at some point - I'm sure it will sound a bit better and it has a USB out so you can transfer to MP3 as well
Posted : 15/03/2013 4:58 pm
Quite!, a Gentleman Mountaineer and explorer should never be without!
Posted : 15/03/2013 5:07 pm
Moving magnet or moving coil?
Posted : 15/03/2013 5:12 pm
