Anyone got any advice about which weed suppressing membrane to use over bare soil with a gravel topping? It will sometimes be walked on, but not heavy use. I'll be planting through it to create a "gravel garden" so want it to be water permeable.
What sort should I get? Standard offering from B&Q? Garden centre? Or online recommendation?
Thanks ๐
Screwfix stuff, or toolstation. Way cheaper the BnQ
we used stuff from a local garden centre. when you put it down its worthwhile pegging the edges down with metal pins. stops the edges rolling up and looking scruffy. also make sure you have a good overlap
Just be aware that some of these membranes are very thin and certain weeds will pierce them easily....so they become a waste of time. If you are walking on it then ensure the level of the membrane is a a couple of inches below the surrounding area, so the gravel sits level.
http://www.avsfencing.co.uk/decking/framework/geotextile-membrane/
I use this stuff. It's good but needs pinning/pegging in. Cut x's to plant in.
Tim
Thanks folks.
To be a bit more specific, ideally I'd like a 4 or 5 metre width so I can use one large piece to cover an area 4 x 5m. Also want it to be strong enough to suppress some fairly persistent weeds like couch grass from pushing through. Happy to pay more for a product that works well, just don't know which is the best?
The 'standard offering' woven black roll stuff sun degrades and can be pierced by determined weeds (* it comes in various thicknesses) imho the thinner stuff (*and poss even the thicker) won't be good enough. So I'd do some reading on weight/thickness.
The stuff I used was white/fabriccy stuff(looked solid more like cloth than the standard black etc weave) - it was expensive, however 15 years later it's still there(even edges that get sunned and mossed) and still working - will have a look in garage when I get home to see if I can find the packet. (FYI bloke down road was doing his drive with same looking white stuff - so you can still get it). Just laid it flat, pegged edges and make sure any joins were well overlapped/pegged.
*EDIT do NOT use pea shingle or it will be used as a cat sh**ery use 30mm or preferably bigger
towzer - that sounds like the "terram" fabric I used to use when building footpaths etc. Robust and hard wearing, but not sure what it would be like to plant through?
Any other advice / experience appreciated ๐
To be fair, with soil above the membrane it'll soon start popping up with weeds anyway.
I did a small patch with some industrial membrane or 'non-woven geotextile' if you like (normally used to underpin rockway sea defences, under train tracks and motorway embankments - its about 5mm thick, all edges heat bonded. Scattered some gravel on it and already (6 months later) some weeds and grasses are coming through - they don't come from *under* the membrane, they take hold above it.
EDIT, I misread the OP, but what I say still stands, you will soon have weeds no matter what you do - plant waste (dead leaves etc) decomposes between the gravel and soon becomes fertile soil.
