Garage flat cold ro...
[Closed] Garage flat cold roof insulation Q
So, my single skin (painted inside & out) garage build is almost complete, it has a felt on OSB roof with 200mm joists, currently no insulation. I've [i]moved in[/i] now with bikes, tools, stuff stored on shelfs. No leaks.
During fitting i cut 50mm off the top section of the noggins to allow for air movement once insulated and boarded.
After a dip in temperatures, this morning anything with a metal surface has a layer of condensation on it and paper stuff is damp.
So i presume i need to insulate the roof to stop this condensation forming? It feels chilly in the garage whilst warm outside thus producing what i call the beer out of the fridge condensation problem.
It is [i]only[/i] a garage and i'd like to keep this as simple as possible and keep costs down, whilst doing the job properly.
So, am i correct in thinking that 100/150mm Rockwool type insulation between the rafters, held in place with stapled garden netting, then finished off with some kind of boarding (plaster/ply?), and it seems the board requires taping?
OR... could i get away with [i]just[/i] stapling some [url= http://www.roofingsuperstore.co.uk/product/kontrol-r19-multi-layer-foil-insulation-125m-x-15m-roll-1875m2.html ]Kontrol R1.9[/url] to the underside of the rafters and be done with it?
Also i believe that the void above the insulation needs venting to the exterior, yes or no?
Many thanks.
Posted : 11/11/2013 8:22 pm
Wont rock wool turn into a soggy mess ?
See if nobeer posts the used celotex site. I used kingspan on mine - 100% stopped the condensation - cardboard boxes dont even go soggy any more ๐Ÿ™‚
Posted : 11/11/2013 8:24 pm
You might find it hard to hold insulation in place prior to the netting without shoving it up tight into the joists.
Posted : 11/11/2013 8:28 pm
I'd hope not but don't honestly know, would it not [i]hold[/i] the moisture until it's vented and evaporates?
In a perfect world of every rafter being square & paralell i think i'd go with the Kingspan stuff, but on mine every piece would be a custom cut due to shonkyness, is this normal? If i used the Kingspan could i just wedge it between the rafters and NOT board it out? A silver ceiling would be nice and light.
Posted : 11/11/2013 8:29 pm
TR - did you also board it out? If so what with?
Posted : 11/11/2013 8:31 pm
You got plenty of ceiling height? If so nothing stopping you nailing full sheets up. Far quicker and less gaps!
Posted : 11/11/2013 8:32 pm
To hold rockwool type insulation in place before the netting use bits of bamboo slightly longer than the gap and just push them in. They will hold surprisingly well which I can testify too after using this method to insulate under our floor.
Posted : 11/11/2013 8:33 pm
No boarding yet.
My garage is like nothing on toast also- as i was reminded last weekend when i stuck up a shelf above the door.
When i do get round to boarding it itll be 6 mm ply.
Posted : 11/11/2013 8:37 pm
You can see it here , kingspan and some expanding foam in any gaps ....not cut for added - bodge effect
Posted : 11/11/2013 8:39 pm
celotex +1. I would only use the R1.9 as part of a complete package ie. Vapour barriers/ breathable membranes Plasterboard/ Timber cladding.
Posted : 11/11/2013 8:40 pm
A eureka moment!!!!
Posted : 11/11/2013 8:42 pm
Polystyrene sheets are very cheap and easy to work with.
Posted : 11/11/2013 8:48 pm
TR / all - what thickness sheet did you opt for?
Posted : 11/11/2013 9:02 pm
Its 50mm
For no other reason than i was using it in other bits of the house already and had a garage full of it .....snuck some off to the garage roof and ordered more ๐Ÿ™‚
Posted : 11/11/2013 9:07 pm
Was there a hint of sarcasm there qwerty? ๐Ÿ™‚
If you use fifty mm board then 75 mm nails with a decent sized head it will hold no problem prior to boarding it with your chosen material.
Posted : 11/11/2013 9:28 pm
Wrightyson - no not at all, I get so bOgged down with these thing I miss the obvious solution! I've picked your brains often enough and appreciate your advice. I'm liking the idea of a foil ceiling, very NASA. Can't see the point of board if I don't have too.
Posted : 11/11/2013 9:41 pm
Still not decided what to use for my mancave roof insulation so watching this one!
Posted : 11/11/2013 11:16 pm
