Garage door woes
[Closed] Garage door woes
Any garage door experts around today?
I've got a Henderson double door on my garage and one of the hinges has failed. There's a large pin joining the arm/spring assembly to the bracket on the frame which has sheared.
Here's a photo of the other side which still works - the round pin is visible in the centre:
[url=[URL= http://i941.photobucket.com/albums/ad260/Legoman_07/garagedoor1_zps6870c53b.jp g" target="_blank">http://i941.photobucket.com/albums/ad260/Legoman_07/garagedoor1_zps6870c53b.jp g"/> [/IMG][/URL]][/url]
I've called 2 repair places and both have said the part isn't available so all the gear would need to be replaced (c. ££900!).
Anyone had any similar experiences? Advice, recommendations?
Cheers in advance.
Posted : 22/10/2013 12:52 pm
* this may be bolleax as I may not quite be getting the problem -ie has just the pin sheared
1 - ebay
2 - can you get a bolt etc of the same diameter and just use it to replace the pin
3 * - google for same problem
Posted : 22/10/2013 12:56 pm
Have had a look on ebay, but no joy. Might look for a complete 2nd hand arm though - that's a thought.
I 'think' the profile of a bolt head would foul on the side of the door. The original has a flattened end, almonst like a big rivet.
Posted : 22/10/2013 12:59 pm
I'd be very careful about bodging anything to do with the springs on garage doors.
I replaced the wire on one side of mine a year or so back - the energy stored in those springs is huge.
You really don't want some bodge job going 'spoing' as your nearest and dearest are walking past.
Posted : 22/10/2013 1:03 pm
There must be a local fabricator who could make one of those pins. What is it? A coin-shaped part and a short bar?
get a bolt and get somebody with a grinder to shave the head - also have a check for low profile bolts
http://www.zygology.com/productcart/pc/viewPrd.asp?idproduct=40&idcategory=38
get a bit of metal that fits pivot hole, cut to length, drill a hole in each end (through) and put on two big washers and 2 big R clips on it either side
Posted : 22/10/2013 1:04 pm
get a domed head coach bolt ?
Posted : 22/10/2013 1:18 pm
Have you spoken to Henderson, last time I needed something for mine, dealt with them directly very helpful, and parts arrived by post.
Posted : 22/10/2013 1:27 pm
that's very true. In fact I'm not sure how I'd stretch the thing far enought to re-join the 2 sections even if I can get a part
no, the local door repair place told me they no longer make garage doors. A bit of googling suggests they still do spares although I can't find the bit I need. Will give them a call anyway.
Posted : 22/10/2013 1:55 pm
Where abouts are you?
Posted : 22/10/2013 2:12 pm
Near St Albans in Herts.
Posted : 22/10/2013 3:28 pm
Open the garage door and then dismantle the arm,it will not be under tension when open. Take it to a local car repair shop to get it welded. Im in the door game, Henderson's are well known(as are all large manufactures) for pulling your pants down on after sales/spares, its where they make there money. A new door maybe cheaper!!! (Hormann, Cardale et al are all the same)
Posted : 22/10/2013 6:33 pm
