Garage And Mould
[Closed] Garage And Mould
Is this generally a problem? Also, is it worth running a dehumidifier on a timer in there to deal with it?
I don't want to cultivate penicillin on my helmet, kneepads and so on. Any tips on protection/prevention welcome!
Posted : 19/01/2014 8:18 am
Normally the gaps around the main door allow lots of ventilation so shouldn't be a problem. You may have issues if you try and make it warmer by insulating and stopping the gale that blows in by the door.
Posted : 19/01/2014 8:22 am
Can we summer it is already a problem? Or are you trying to prevent a problem?
Or garage is only ventilated by the gaps around the garage door. Had a dehumidifier for a while because we had a load of books in there but the house took priority and a couple of years with only natural ventilation has seen no real change. Dehumidifier would only make sense if you really went to town sealing it up I suspect.
If your riding gear is being put away wet and getting manky it may need somewhere warm in the house to dry before getting dumped back out?
Posted : 19/01/2014 8:27 am
 br
[i]If your riding gear is being put away wet and getting manky it may need somewhere warm in the house to dry before getting dumped back out? [/i]
This.
Posted : 19/01/2014 8:29 am
Mould thrives in dark moist places, you need air circulation to cure it.
A dehumidifier will take the moisture out of the air, it won't help your problem.
CF
Posted : 19/01/2014 8:57 am
Yes, it is already a problem. Not a major one, but bad enough. The recent rain has exacerbated a leak which the builder is looking at soon.
Not so much for wearable kit. That gets put in the house first to dry/wash anyway. It's things like wheel bags which for some reason have got mould on them. How can I prevent this in addition to addressing the circulation problem? Is there a protective/preventive spray or something for fabric?
If air circulation will help then is it worth mounting an RVK fan in addition to a dehumidifier without having to put in a ventilation point?
Posted : 19/01/2014 9:10 am
I have just put soffit vents along my garage fascia boards and it has virtually eliminated the condensation problems I was having.
Posted : 19/01/2014 9:22 am
Don't have that option I'm afraid. I'll have to vent through the garage or access door.
Is this generally not considered when building a house? Suprising if it's not.
Posted : 19/01/2014 10:09 am
Edited for double post.
Posted : 19/01/2014 10:10 am
You don't need anything fancy. An airbrick (or two) and access door vent will do.
We found using a condensing tumble dryer caused issues in our garage, but this was solved with some basic vents.
Posted : 19/01/2014 8:00 pm
But it would cure the symptom which is just as good as curing the problem.....
Posted : 19/01/2014 8:33 pm
โ“ If you had a dehumidifier on and left the door open, would it create arid desert trails outside ???
Posted : 19/01/2014 8:37 pm
But if you have any ventilation at all, you will be trying to dehumidify the world.
Posted : 19/01/2014 8:41 pm
Ventilation is limited to the air gaps around the garage door. I could plug them up, or line the door and use a dehumidifier.
Long term I need to look at eliminating the source of the leak. Which is increasingly looking like the roof and a wall in the corner. The short term problem is dealing with the mould.
Posted : 20/01/2014 9:18 am
Bleach....
Posted : 20/01/2014 9:26 am
Blasted thing is growing on bits of my wheel bags and my bike bag. Wonder if something like Scotch Guard will sort it.
Posted : 20/01/2014 6:02 pm
Wash it off with a mild bleach solution.
Posted : 20/01/2014 6:05 pm
