[Closed] Galaxy s4 battery used quickly in the last 2 days.
Someone posted on here recently about battery drain and a clever person said that the Facebook messenger app was the problem.
How was that resolved?
If it's not messenger is there a current rogue app?
Dunno, mine says 15% of the battery was used by facebook (settings -> more -> battery), messenger doesn't appear I don't use messenger often, presumably it's still on in the background somewhere.
I has taken to dying absurdly quickly some days though so maybe that was the problem.
Have you got Amazon Music? That was chewing my battery so I uninstalled it.
You should be able to tell what's causing the biggest drain by looking in the settings-battery use thingy.
How old is the Galaxy? My S2 got to two years old, and typically it would need charging again by lunchtime. My 2 year old Galaxy Ace work mobile appears to be going the same way.
I had a Galaxy S4 mini.
Battery life got worse the older it became. After two years it needed charging twice a day.
I changed to an iPhone 6S. 15 months on the Battery still lasts as long as the day I got it - can go two days without needing a recharge if I'm too busy to use it ๐
Ahh yes, but you can change the battery for a new one in an S4, you can't* in iPhone* :p
*without screwdrivers and special tools.
Brexit
