Gaggia Classic woes...
[Closed] Gaggia Classic woes - help me please before I go mad!
I have a Gaggia Classic and recently upgraded to the (pre-modded so no cutting required) Rancillo steam wand, however when I took the existing wand off, the little rubber gasket (part 41 on the diagram) was cracked/corroded so I ordered a new one. In fact I also bought a spare as the part was pennies and the postage silly.
Anyway, I fitted it after struggling for a while as it simply wouldn't fit on properly as the gasket was slightly too big (the wand fits fine without it fitted) and after pushing very hard I got it on but it ripped the washer and lost steam/water and pressure from around the seal. So I tried it again with the spare and the same happened.
So I then looked online and found a supplier that claimed to do official Gaggia spares – the wand now goes in more easily as the washer is slightly smaller yet it is still losing water/steam from the seal despite it being tightened up as hard as it will go.
I have compared the new wand to the old and it does look pretty much identical to the original around the fitting so I am at a loss as to how many times I will have to keep buying and fitting gaskets before I get it to fit.
I was wondering about trying a bit of PTFE tape around the screw fit but I am not sure if this might be a good idea or not.
Anyone experienced the same / got any help / advice / suggestions?
Thank you.
Posted : 02/02/2017 3:09 pm
Had similar issues with our Jura F50.
PTFE tape should do the trick, 3 - 4 wraps should be enough.
I'd maybe take it easy on tightening things "as hard as it will go"...small threads on nuts / bushes / olives can easily split if over tightened. Check you've not got any hairline cracks when everything is tightened up.
Posted : 02/02/2017 4:20 pm
Would you PTFE in place of the washer or as well as? I assume it is fine with high temperatures seeing as it gets used on central heating systems.
Posted : 02/02/2017 4:44 pm
I'd try it will both as the washer isn't obviously working.
Posted : 02/02/2017 5:32 pm
