I bought one of those Aldi satellite kits mainly to get a digital receiver so that I can pick up digital Eurosport now the analogue signal has gone. For the moment I've got it connected to my old dish and luckily it has a universal lnb connected. So I thought all I had to do was make sure the receiver was set to pick up the signal from the Astra 1 satellite and the rabbit's in the hole! I've done a normal scan and a blind scan and I cannot get Eurosport. I get other channels, mainly German, so it appears the dish/lnb/receiver setup is all good.
What am I not doing right?
Check if transponder 12226 MHz (H-pol, 27500 bit rate) is in the list. If it's not, add it manually, and rescan that transponder.
If it was there, then dunno.
http://www.lyngsat.com/Astra-1H-1KR-1L-1M-2C.html
and
http://en.kingofsat.net/pos-19.2E_eng.php
are handy to know what there is to see. These cheap FTA boxes usually have Astra 19.2 pre-programmed, but they're not always totally up to date.
Thanks! That sorted it!!!
