Looking at Charles Tyrwhitt for a white formal shirt to go with a dark suit. The last time I bought a shirt was from Burton's over a decade ago, which should tell you all I know about shirt buying. I know there's a few advocates of CT here, so hopefully someone will be able to help.
I can't seen to find anywhere that explains the sleeve measurement, and the figures seem huge to me. How is this measured? Only way I can see that makes any sense is from the middle of the neck, over the shoulder and down to the cuff edge. Is that right? I guess too long is better than too short?
Twill, imperial twist, poplin, herringbone, end-on-end what's all that about then? How do I choose? I guess poplin or EOE is the way to go, says they're lighter and I don't to be sweating like a stuck pig.
Help me [s]Obi-Wan[/s] STW, you're my only hope.
Everything you need here (warning, contains boobies) http://www.incrediblethings.com/style-and-gear/spray-on-shirt/
Not CT but sizing will most likely be the same as this guide from a competitor
http://www.tmlewin.co.uk/Size-Chart-Tabs/Size-Chart-Tabs,en_GB,pg.html
Poplin is closest to what you imagine in standard shirt.
Twill a bit thicker (I think)
Herringbone has subtle pattern
I assume you read this
http://www.ctshirts.co.uk/Formal-shirts-sizing-guide?cnt=sizing-guides
FWIW, code AMAZON16 will get you £10 off your order.
(Mr Cheap here; happy with a shirt for £15, delivered)
Aha! Top find, thank you. The 'bent arm' photo was the detail I was missing.
I've got a code on a flyer, but that's better I think. Ta.
Pleasure, my friend!
Its very much like the handkerchief code
Yeo, don't want to send the wrong messages otherwise you could end up in all sorts of bother....
Actually, mine's better for shirts over £33. QWYT is all shirts at £22.95 (code expires tomorrow, fill your boots).
Oh, and Topcashback gives me another 10%, bargain.
