ford focus reverse ...
[Closed] ford focus reverse light fuse, where?
any owners of a ford focus 2ltr TDCI MK2 2006? reverse light is ok and new but light doesn't turn on ๐Ÿ˜
Posted : 04/12/2013 5:58 pm
Owners Manual in glovebox?
Posted : 04/12/2013 5:59 pm
looking for it atm actually, i know it is somewhere in the house ๐Ÿ˜ก
Posted : 04/12/2013 6:05 pm
cheers, but I swear I cannot find the "reverse light" fuse in them manuals .. I scan it twice ๐Ÿ˜
Posted : 04/12/2013 6:28 pm
Usually its the reversing switch on the gearbox which fails. Easy fix.
Posted : 04/12/2013 7:34 pm
Unlikely to have its own fuse i'de have thought. Probably grouped with something.
Posted : 04/12/2013 7:56 pm
Not sure which one it is off the top of my head but it is in the back of the glove box group. Iirc
Posted : 04/12/2013 8:02 pm
In fact thinking about it im gonna guess the fuse is ok. It is in fact the cup that the bulb sits in thats kaput. New cup is a couple of quid
Posted : 04/12/2013 8:10 pm
i had a non-working reversing light with a bulb that was fine on my Focus. Turned out it was corroded contacts. The housing that the bulb screws into is clearly not 100% waterproof - or not after some years, and with it being positioned in the wheel arch being sprayed with all the road crud time soon takes its toll. The bulb holder/housing plugs into the loom, so you can remove it. I was all set to buy a new one, but decided to give cleaning up the contacts a go, so with a bit of fine wet'n'dry I sorted out the corrosion and it worked fine after that.
I don't think individual light bulbs have their own fuses - they are in effect fuses in themselves. Probably why you're struggling to find it.
Posted : 04/12/2013 8:13 pm
 core
^ What he said.
Posted : 04/12/2013 8:32 pm
