Ford Focus 2.0 TDCi...
[Closed] Ford Focus 2.0 TDCi turbo whistle...
We've got a 57 plate Focus 2 litre TDCi, the turbo has suddenly got louder, no smoke or loss of power though. What's the likely cause and should I be worried?
Posted : 20/06/2013 9:23 pm
Is it a whooshing air noise? if so could be an early indicator of an intercooler hose splitting.
Had this with my Mondeo. A few days of it then the smoke and power loss. Less than 200 to fix in fact think.it was nearer 100.
Failing that someone else will be along.
Posted : 20/06/2013 9:38 pm
Often oil feed problems, either caused by lack of servicing, or on some there is a gauze which blocks up, peugeots have been particularly prone to this. For a common model like a focus in the main the cost of a replacement turbo isn't too bad, seen prices as low as £200 for the unit for an astra, fitting is obviously extra.
Posted : 20/06/2013 9:40 pm
@benji - Thought that was only a problem with the 1.6 Ford/PSA turbo diesel engine?
Posted : 20/06/2013 9:43 pm
As above, get under the bonnet, flex the intercooler pipe about and thoroughly check for any splits.
Could also be a leak in the ducting on the intake side of things, or around the airbox.
Posted : 20/06/2013 9:47 pm
As previous it sounds like the split hose I had on my ford. 50 for the new hose
Posted : 20/06/2013 10:28 pm
Split hose, but it is usually accompanied by power loss though...
Posted : 20/06/2013 11:10 pm
