For shame, an excel...
For shame, an excel question...
I want to do a line chart where I have multiple lines for quantities of a certain thing at certain dates across the year, for different years. The aim is a visual representation of how the amount of that thing has changed through the year, to allow comparisons between use of that thing in different years.
Simplified Imaginary Raw data:
20.01.20 - 10 things stocked
23.03.20 - 9 things left
14.04.20 - 8 things left
12.12.20 - 1 thing left
13.01.21 - 10 things in stock again
11.02.21 - 9 things left
10.03.21 - 8 things left
28.11.21 1 thing left
I'd like a graph with number of things on the Y axis, date in the year on the X-axis, with a line for 2020 and a line for 2021. The lines would be one above the other to show, in this example, how the things ran out more quickly in 2021 than in 2020.
Ideas?
Posted : 22/12/2022 5:27 pm
Just put the dates in 4 digit format ie without the year.
On two separate lines.
Or add year to the first year and don't include year in the axis legend
Posted : 22/12/2022 5:32 pm
i hate trying to do charts with a date axis.  There are always clever ways of doing it but it takes me hours of googling 🙁
I would do two things.  First add an extra column to calculate the day part of the year, e.g. =B3-DATE(YEAR(B3),1,1)+1 if the date is in cell B3
Then add a scatter chart with straight lines between the two points and add the two years separately by right clicking on your chart, the select data range, then add series twice - once for 2021 and once for 2022.  Each time you can name the range e.g. 2021/2, select the X axis as your day number range that you added and then the Y axis as your values
I suspect there is a slicker way though
Posted : 22/12/2022 5:44 pm
Screen shot of the Excel sheet copied into MS Paint.
Use MS Paint to draw the lines.
Copy the picture and paste into a Powerpoint presentation*
*This will work for the sales pitch and then it is the developers problem
Hope that helps
Posted : 22/12/2022 6:31 pm
Stacked Line Graph isn't it?
Posted : 22/12/2022 8:38 pm
The answer you need is R.
Excel is awful with non-categorical horizontal axes. It can do it but…
The number of bad plots I’ve seen with allegedly scalar or vector x-axes that turn out to be shonky excel categories seemingly never ends.
Posted : 22/12/2022 8:51 pm
you could also do the scatter with straight lines thing, but if instead of day numbers you still wanted days and months then do a cheat where you add an extra column to make all of the dates in the same year e.g. =DATE(2021,MONTH(B3),DAY(B3))+1 if the date is in cell B3
then format the X axis to show only day and month, so 'dd/mm'
then just add the two series for 2021 and 2021 as before by right clicking on the chart and editing the series
but ugly when it should be straightforward
Posted : 22/12/2022 10:00 pm
I’d use WEEKNUM on each date, and graph the data with weeks on the X axis. This is good if you are interested in variation across or between years, but obviously no good for Monday to Friday changes.
Posted : 22/12/2022 10:34 pm
Has anyone tried this https://excelformulabot.com/
Posted : 23/12/2022 11:36 am
