flushing a car radi...
[Closed] flushing a car radiator without a hose pipe or dirtworker
Need to flush the coolant system in a car, but do not have access to a hose pipe or dirtworker etc. Car cannot be moved either at the moment.
Any bright ideas on how to get some water flushing though the system?
Thinking of a length of hose, a funnel, and a bucket or two.
Thought about getting a large watergun and attaching a length of hose to that ( with the added advantage of having a toy afterwards!! ) but they only hold about a 1 litre of water and may blast water in too harshly.
Posted : 05/06/2013 2:44 pm
Why not just drain the system, run it on clean water until it warms up, drain and repeat until cack stops coming out?
Or. (**Disclaimer** - I have not done this, but lets get creative)
Disconnect the bottom pipe and stick it in a bucket of water. Stick something under the radiator to catch the waste. Run the engine.
Posted : 05/06/2013 3:08 pm
yeah could do thanks. Gonna be using a product though I think it needs to have cold water run through without pressure. Also at this stage not sure if it's just the rad or the whole system that I use the product in.
Just looking into things at the moment and trying to generate some ideas.
Thanks though worth considering.
Posted : 05/06/2013 3:17 pm
im curious as to how it can be worth flushing your rad but not worth finding a hose ? - do you suspect a blockage ?
do you live in a 3rd floor flat ? can you not just run a hose from your/your neighbours kitchen tap ?
Posted : 05/06/2013 3:20 pm
No chance of a hose at all. Thanks think I've solved it now.
Posted : 05/06/2013 3:25 pm
