Fixing solution fro...
[Closed] Fixing solution from smart people, please?
I'm looking for a solution to a small problem I have.
I need to get two pieces of metal together and a toggle bolt would be the perfect solution, except I'm looking for something that is reusable and dropping the toggle is not a solution.
I've looked at [url= http://www.toggler.com/products/snaptoggle/overview.php ]these [/url], but I guess they are reusable because the anchor bites into the inner surface.
Can anyone offer a solution or places to look?
Posted : 02/02/2013 7:00 pm
Ironmongery direct and hafele are good for fixings. Not quite sure what you need.
Edit. Or do you mean something like a temporary rivet like a cleco?
Posted : 02/02/2013 7:21 pm
Something like this might work if it can be extracted as a whole.
The key is being able to remove the fixing without leaving any debris on the inside cavity.
Posted : 02/02/2013 7:28 pm
These work quite well.
Not sure about in thin metal though.
Posted : 02/02/2013 7:31 pm
Not sure what you're trying to do, could you not just tap the back piece?
No tapping as it's thin aluminium, think like ducting where I can't leave anything in the duct but need to attach something to the outside that isn't a permanent fixture.
I'm pretty sure there's nothing, I can have a look at the suitability of those hollow anchors.
Thanks all.
Posted : 02/02/2013 7:38 pm
The cleco will do that. http://www.skinpins.co.uk/fastclecotemp.html
Posted : 02/02/2013 7:42 pm
http://www.fixingsupplies.co.uk/clips/spire-clips.html
spire clips? depending on how far away from the edge of the ducting you need to be
Posted : 02/02/2013 7:46 pm
How heavy is what you're trying to attach and does it need to be re-attached once detached?
Nutsert
Posted : 02/02/2013 7:51 pm
Thanks nickjb, I don't think they will.
I'll have to wait until I can get into Screwfix or whoever. I haven't got a way of putting up drawings to illustrate exactly what I'm trying to do and I'm not doing so well explaining it. ๐Ÿ™‚
Cheers for your help but there's more important things to worry about on a Saturday night.
Rivnuts?
Avdel nutserts www.avdel-global.com . The site shows a fixing tool, but you can use a bolt and washer to crude effect
Posted : 02/02/2013 7:52 pm
The more I look, the more I think the hollow wall anchor is the type of thing I need.
Thank you very much.
Posted : 02/02/2013 8:03 pm
You can get rubber hollow wall anchors which are re-useable / removable - have used them in the past.
Posted : 02/02/2013 9:04 pm
