"Fit to fly" latera...
[Closed] "Fit to fly" lateral flow tests?
Going to France soon and need an antigen test within 24 hours before arriving. Any recommendations for a supplier that is cheap, straightforward and reliable ? (yers, I know I'm asking for the moon on a stick!!)
Posted : 30/01/2022 8:20 pm
https://www.testingforall.org/
We used these for Fuerteventura last year- very straightforward and transparent pricing.
Posted : 30/01/2022 8:22 pm
How are you getting there? We got the ferry from Hull and did one at the port, mostly because it was a very last minute trip and hadn’t done any planning or research. It was so straightforward though that I’d do the same again.
I assume other ports / train terminals are similar.
Posted : 30/01/2022 8:29 pm
We just flew from Manchester and used Randox in the terminal before checking in ( pre-booked) . Pretty much immediate results and no hassles.
Posted : 30/01/2022 9:01 pm
Same as geomickb
Posted : 30/01/2022 9:03 pm
Boots. Delivered to your door, upload a photo of result to their portal, get certificate in seconds. Couldn't be simpler
Posted : 30/01/2022 9:13 pm
Did Randox on Friday morning before leaving for the alps a couple of hours later. The certificate arrived on the app in under an hour.
Posted : 30/01/2022 9:26 pm
Testing for all worked fine for me.
Posted : 30/01/2022 9:28 pm
Flying from Newcastle, and early so I don't want to have to get there even earlier 🙂
Testing for all is a good shout. I remember we used them for Day 2 tests once before. Thanks!
Posted : 30/01/2022 9:31 pm
