Firewall/AV recomme...
[Closed] Firewall/AV recommendations please
Hi,
I usually use Comodo for firewall and AV but for some reason, when I install on the new (secondhand but clean) laptop, it knocks out my wireless connection and I just can't figure it out .... Uninstall brings the connection back again.
I'm not a techy person, so any other recommendations for firewall freeware?
Thanks,
Posted : 23/08/2009 8:14 am
I use Avast for AV and the routers NAT is good enough firewall for home use.
Posted : 23/08/2009 8:47 am
The router is OK? OK, I'm good with that.
What about using laptop when away from home? Any issues there?
Thanks,
Posted : 23/08/2009 9:02 am
Some will come along in a moment so no router isn't as it can be hacked, the chances are more than slim of hacker wanting into your home account.
Maybe while on a network away from home your not sure of then yes enable a FW windows own would probably suffice but there is plenty out there for free. Bit out of date with them though as to which one is best.
Posted : 23/08/2009 9:40 am
i wouldn't worry about the router getting hacked but i'd still stick a firewall on your pc even with a nat router as this won't protect your machine if you get a trojan / virus on your pc
you'd need a firewall which can block outbound connections, i've used zonealarm in the past and not had any problems with it.
Posted : 23/08/2009 11:19 am
