Fire cement
[Closed] Fire cement
I've had cause to remove my stove from its usual place.
Wondered if its just a case of cementing the flue pipe back in and siliconing the top section round the flue at the chimney?
Posted : 20/10/2014 10:30 am
I renewed the fire cement on mine last week at the flu, then where it enters the chimney I resealed that with fire cement too as it goes through sandstone on ours.
Posted : 20/10/2014 10:33 am
Ah cool, its a fire board above mine.
Posted : 20/10/2014 10:34 am
you got one of those annoying stoves you have to pull the flue out of to sweep as well...
pending stove design - i have to fire cement the T into the backof the stove adaptor but the rest gets high temp silicone - like what with it came installed with.
just be carefuly you have stove flue temp rated stuff and not gas flue rated stuff - both are called high temp silicone.
Posted : 20/10/2014 10:36 am
Many thanks will check temp rating.
Posted : 20/10/2014 10:40 am
