fencetrackworld - e...
[Closed] fencetrackworld - erection advice
5 Users
Good evening all
Can anyone tell me how I go about fencing round a non-right angles.
I need to put a fence up round the lawn so it will come down the edge to around a 60 degree, along a bit and around another 60 degree angle then to the wall.
How do I get it round the 60 degree angles?
Thanks for your help all
Danny B
Posted : 05/06/2013 6:29 pm
Fencing is basically a modular system comprising of posts of various lengths and rails that are 3.6 metre long. Therefore the post centres are 1.8 meters apart, so post round your 60 degree curve/ angle using the 1.8 metre spacing. Ok?
Posted : 05/06/2013 7:16 pm
[i]Ok?
[/i]
I haven't a clue what you just said 😆 Did it even relate to the question?!
I think I'd just find a bigger alternative to those fence clips so the panels can have a gap on the outside of the corner. Position the post so it is at an angle to both fence runs, i.e 30 degrees to each one, so you have a small gap both sides rather than a big gap on one side.
* not in any way a fencing expert.
Posted : 05/06/2013 7:47 pm
Not quite I'm afraid - the posts are square so how do I attach the fence to the posts to make it round the angles?
Danny B
Posted : 05/06/2013 7:52 pm
Ah, panels, I assumed you were erecting screen ( vertical slats) in that case as you say angle the panels between the posts to 'curve round ' No need for fancy clips though just cut wedges and screw through to the post.
Sorry for the long winded reply.
Posted : 05/06/2013 7:53 pm
I was going to suggest wedges but was worried it might be a bit 'bodgetastic' 🙂
Posted : 05/06/2013 7:57 pm
Wedges are fine mate, if one is 'erecting' out in the sticks then one is forced to improvise!! Assume OP is using timber posts rather than concrete H posts.
( used that method for years )
Posted : 05/06/2013 8:02 pm
Thanks all - wedges it is for the erection.
At last Mrs Danny will be happy (for around minutes). Its neen a faff to get this far.
Two years ago she decided she didn't want a lawn so having ordered then wheelbarrowed a ton and a bit of gravel round to the back of the house she had a nice gravelled area.
Now, with babybgoode just starting to walk she decided she wants lawn again so have now shifted a ton and a bit of gravel back round to the front, dug the ground over and turfed it.
The fence will just finish it off...
Cheers all for your help
Danny B
Posted : 05/06/2013 8:17 pm
You could've done this a month earlier, I recently paid for two bulk bags of 'brand new' gravel! And its not even on show...
Posted : 05/06/2013 8:25 pm
I hope your erection will please Mrs DBG...
Posted : 05/06/2013 8:49 pm
two posts in the hole where angle is needed
Posted : 05/06/2013 8:52 pm
