when i build my dream van type thing can i....
have a water tank filled by rain water and heated with a solar panel and pumped by a polar battery pump thing to wash my fantasy surf board and bikes etc?
can i have a wifi router which uses a sim card? you know, 3g type thingy
can i use led interior lights powered by batteries topped up by solar stuff?
can i use LPG for the fuel as well as heating and cooking, if it's a diesel engine? ( i suspect this is the Q that exposes my thickness)
can i have a wood burning stove in a modern van type conversion thing?
that will be all for now, i shall get back to the Jura.
Yes
Yes
Yes
No
Yes
Can I have one with a washing machine?
That's been exposed for ages ๐
It's your fantasy, you can have whatever you want! Even lightsabers or camperspaceships
for a washing machine, you just need a big plastic tub with water and detergent, then drive around a bit then rinse. works a treat.
I KNEW the LPG answer, just wanted to be extra extra sure before I win the lottery and buy the wrong van.
I vanlicker
I would worry about camperspaceships given the debris in the solar system. but good point.
No worse than the potholes round here.
Read somewhere that there are 2million in the UK. That is quite clearly absolute rubbish as there are more than that between Osbournby and Donnington on the A52 alone.
my fantasy campervan will hover above the A52
Firstly, rain water isn't really for drinking, and you haven't got much of a roof to collect it. Its not practical to heat anything by battery power, not with the amount of solar panels you could fit on the roof anyway.
3g dongle, yes.
LED lights, yes. batteries can be kept topped up by panels but most of your charging is normally done with a split charge relay and the alternator.
Get a diesel. You can get a vapour take-off LPG tank for air heating, water heating and running the fridge. If you got a petrol, you would still need separate LPG tanks as one needs to be liquid take-off and one vapour. I have a tank, saves valuable space over cylinders and I can top up as necessary instead of waiting to empty a cylinder.
Wood burning stove, technically yes but insurers will run a mile, they take to loads of room, and make you look like a traveller!
Have a word with Tony at ACare in Crowcombe - he'll sort you out.
I was there this morning to see about replacing the heat exchanger on my water heater (I stupidly didn't drain it before the -10c frost split it)
