Don't want to spend loads but don't want tat.
Got a few furniture projects in mind as well as a camper build
Not be anything from Netgear or D-link then... My bad.
Wireless or wired? 😉
I've had cheap ones, and then took a punt on a s/h Trend T9.
Buy a Trend T9 🙂
[url= http://www.diy.com/departments/mac-allister-1500w-mro1500a-plunge-router/189207_BQ.prd ]Macalister[/url] one worked for me doing kitchen work tops.
Yeah, parkesie's Macalister one is pretty good. Just bear in mind that spares availability is zero!
I've got a couple, but this tiny Bosch thing is really nifty.
http://www.axminster.co.uk/bosch-gkf-600-palm-router-kit
Ordinarily i would say makita 1/2 inch but given the scope of work .... Footflaps bosch would be the winner 1/4 inch bits cheaper too 🙂
I've got a crappy Silverline 1/2" I bought in an emergency for doing kitchen worktops. It's rubbish. Bolts come undone, adjustment screws have rusted and the knobs fallen off. Don't buy a cheap router. They are scary enough without the risk of it trying to kill you.
We had a 1/4" one but needed a larger one for the worktop cutters.
Now I want something a bit less bulky and was looking at that small 600W bosch (£100 in screwfix + £50 for the plunge part as both ave 33% off at the moment) or the Makita one has adjustable speed but not sure if that is needed or not.
I've got a Bosch one as well but not as fancy as that. Brilliant bit of kit
The best thing about the Bosch one is how little space it takes up. I've got a 1/2" Bosch one, but it's a beast compared with the 600W palm job.
We have Bosch come in to do demos where I work (furniture making course) and he demoed that little one. Brilliant bit of kit.you can get different bases I believe which extends its use.
Bosch stuff seems well designed and good quality.
Depends on the work you want to do with it really.. if it's heavier work, a 1/2" router may be better,, perhaps mounted inverted in a table as a mini spindle moulder.
It comes with 3 in the box IIRC. If you really want to know, I can nip out to the workshop and photo the set.....
OP If you're anywhere near Cambridge you can borrow it for a play...
Thanks all I was looking on the Axminster site but just so much choice I did not know where to start
Love my Bosch palm router. I have 3 routers. A huge one, a mid size and the little Bosch. I use the Bosch for 95% of jobs.
%20r39249v35.jpg)
