So, I've pulled the old (WinXP) hard drive out of our old desktop pc so I can remove the photos from it. I've put it into a usb caddy and plugged it into my laptop. When I try and navigate to the drive it says 'please insert a disk into drive f'
Please tell me there's something I can do to take all the old baby photos off the drive? And no, I didn't take a backup ...
You probably know this but they should both be switched on before you plug the usb in, I think.
If your worried try it back in the old desktop and get the files from it that way?
Trouble is the old desktop is boxed up in the loft!
Trying the quick solution first ...
This ^^
Also, make sure it's plugged into the caddy firmly. Removing and reseating might be sufficient.
IDE can be funny about hot-swap. Try a reboot after you've plugged it in and connected the caddy?
Does the caddy have / need power? Power over USB may well be insufficient for an old drive.
