Excel wizzards cond...
[Closed] Excel wizzards conditional formatting of columns HELP please.
My google fu is weak today, hoping someone on here may be able to help.
I am trying to format an excel sheet so that if a date appears in column G then the status column C changes from Open to Closed.
I am hoping this is not too complicated and someone who uses Excel on a more regular basis than myself can help.
Thanks
Rusty.
Posted : 02/05/2013 1:53 pm
convert the date to Universal time code them > if thingy
Posted : 02/05/2013 1:56 pm
Not perfect, as someone entering "12345" would do the same, but:
In "C2" enter =if(and(isnumber(G2),len(g2)=5),"Closed","Open")
Or, if using current dates, rather than historical ones:
=if(and(g2>41000,g2<43000),"Closed","Open")
Posted : 02/05/2013 1:59 pm
rondo,
Just for clarity i should enter the formatting on Column C
Currently i had Column G formatted with the following but it doesn't work "=AND(E2="<TODAY()",$C$2:$C$229="Close")"
Will clear mine and try yours
Posted : 02/05/2013 2:01 pm
Enter the formula in C2 & drag down as far as your corresponding data.
Posted : 02/05/2013 2:03 pm
Ok so i messed up in my innitial post dates were in column E
However Rondo FTW
got it to work when i swapped the G's to E's in his code. Thank you very much sir.
Posted : 02/05/2013 2:08 pm
