Excel type question...
[Closed] Excel type question.... have I got my sums right?!
Need some reassurance that I've got this right... I've created an Excel spreadsheet to help me calculate the best value dressed redwood from a timber merchants. I've got the thickness, breadth, worked out the cross-sectional area, then the volume per metre length, number then required for a metre cubed, then price...
Plan is to build a laminated workbench, btw. If my spreadsheet is correct then the second best option would be my preferred - 45 x 95mm.
Ta!
Posted : 07/04/2017 10:04 am
Are you making a solid cube of timber?
Posted : 07/04/2017 10:07 am
Have you thought about wastage? You don't actually want a cubic metre of timber, you want a piece of XxYxZ for a workbench. If you want a worktop 35mm thick then paying for 45mm thick is a waste of materials, even if it's cheaper on paper.
As you say 90x45 would be preferable I'd say you're fine though. Although why not just go for 145x45 as it's 20% cheaper?
Posted : 07/04/2017 10:08 am
No - that was just a cost comparison method!
Ta. The 145x45 would be a bit overkill in terms of thickness but a laminated top 95mm thick would be ideal.
Posted : 07/04/2017 10:14 am
....and an irrelevant one.
Unless you're buying it by the cubic metre.
Pick the lowest linear metre rate that's thick enough to meet your needs.
You may be overthinking this a bit.
Posted : 07/04/2017 10:20 am
Yeah - undoubtedly!
Posted : 07/04/2017 10:24 am
Are you talking about using lengths of timber , butted together to forma solid top?
If so, the calculation you need is cost per m2 of surface area so you need to work out how many 1 m long widths of each size of timber you would need to form the width of workbench you require and then multiply that by the linear metre rate for comparison.
e.g you would need twice as many 45 x 45 than 45 x 95 to form a 45mm thick worktop.
Posted : 07/04/2017 10:29 am
Indeed. The same timber would also be glued together to make the legs, etc. It would be a variation on the Paul Sellers design:
A top 95mm thick would be ideal, as would legs 95 x 90mm.
Cheers.
Posted : 07/04/2017 10:37 am
Ah ha, I was assuming you were going for 45mm thick, with 90mm width, not t'other way around.
I'd go 45x90 then.
Posted : 07/04/2017 10:48 am
