Excel problem - sum...
[Closed] Excel problem - summing multiple number values in a text cell
I've a workbook which has a text column which can contain multiple number values per cell separated by a backslash e.g. 10/20/5. Any easy way to sum each cell contents and put it into another cell?
Ta.
Posted : 11/03/2019 3:05 pm
You can find the position of the / using a formula and extract the text to convert to a number.
The simple way would be to sort out your data source properly otherwise it will be unreliable.
Posted : 11/03/2019 3:07 pm
Data tab>text to columns> delimited, then other and enter / in the box
Posted : 11/03/2019 3:13 pm
are there only ever two backslashes?
Posted : 11/03/2019 3:16 pm
You can do lots of fettling with search depending on how many values you expect. If it's heaps, it will get unwieldy.
https://support.office.com/en-us/article/split-text-into-different-columns-with-functions-49ec57f9-3d5a-44b2-82da-50dded6e4a68
Posted : 11/03/2019 3:34 pm
if there are just two then...
=LEFT(A1,(FIND("/",A1)-1)*1)+LEFT(RIGHT(A1,LEN(A1)-FIND("/",A1)),(FIND("/",RIGHT(A1,LEN(A1)-FIND("/",A1)))-1)*1)+RIGHT(A1,LEN(A1)-(FIND("/",A1)*1+FIND("/",RIGHT(A1,LEN(A1)-FIND("/",A1)))*1))*1
where the text entry is in cell A1
Slow lunch today...
Posted : 11/03/2019 3:43 pm
OK, I googled for this.
Create a custom function:
1. Press Alt + F11.
2. Choose Insert→Module in the editor.
3. Type this code,
Function Sumthem(Rng As Range) As Variant
Sumthem = Evaluate(Application.Substitute(Rng, "/", "+"))
End Function
4. Save the function.
5. Return to Excel.
6. Use your user defined function just like you would any other by either typing =Sumthem(A1) or finding the function usign the 'Insert Function' button and looking under 'User Defined'
Note I called the function 'Sumthem' change it to whatever you fancy and I used A1 as an example but your array will be in whatever cell it is in
Posted : 11/03/2019 4:09 pm
BTW it is rather simple and assumes you have numbers separated with a / that can be changed to a + and treat the whole lot as a simple calculation.  Chuck in anything more complicated and it may go rather wrong
Posted : 11/03/2019 4:13 pm
Haha are you a SOLA? can't ask the customer to change their workbook.
I want to do it automatically, on the fly for use I other calculations in the workbook not just apply it to a static set of data. Thanks though.
Good question. No. Any amount of backslashes (within reason)
Rubber_Buccaneer - I tried that, it's similar to what I first tried where I used a substitute function to change the backslash to a '+' symbol, but excel does not want to evaluate the resulting sum.
Thanks to everyone so far.
Posted : 11/03/2019 4:20 pm
likes the rubber_buccaneer solution 🙂
remember that your xlsx file now needs to become an xlsb file as it will have a macro/vba code in it (I think)
Posted : 11/03/2019 4:21 pm
 I tried that, it’s similar to what I first tried where I used a substitute function to change the backslash to a ‘+’ symbol, but excel does not want to evaluate the resulting sum.
You created the custom function?  I tested it in Excel 2007 and it worked as expected
Posted : 11/03/2019 4:31 pm
leffeboy is right about this.  You should get a warning when you go to save
Posted : 11/03/2019 4:36 pm
I've no idea about the answer to your question, but that's not a backslash, it's a forward slash (or if you like, merely a slash).
Posted : 11/03/2019 5:06 pm
Thanks Cougar, I never remember, my brain can't seem to work it out.
Posted : 11/03/2019 5:14 pm
The evaluate function no longer worked directly after Excel 2010 IIRC
Posted : 11/03/2019 6:19 pm
Sorry Stevet1, working in a cutting edge IT environment means I'm using twelve year old office on a fifteen year old desktop☹
Just tried my suggestion on Office 365 at home and it didn't work.
So, from a different angle here is another suggestion/variation
1. say A1 contains 11/12/13/14
2. Stick your cursor on B1
3. go to the 'Formulas' menu and choose 'Define Name' from the ribbon
4. enter a name, e.g. sumthem
5. in the Refers to: box type =EVALUATE(SUBSTITUTE(A1,"/","+"))
6. in B1 type =sumthem and hit enter
and that works for me in Excel 365. You can tweak for your data. As described I think it will always be applied to the data in the cell to the left and can be autofilled, pasted etc like any formula
Hope it works this time
Posted : 11/03/2019 9:01 pm
