EXCEL Pivot table h...
[Closed] EXCEL Pivot table help
I can use Pivot tables to do what i need apart from one thing.
When adding fields into the 'Values' section, it defaults to count the number of values rather than sum. I can change each manually, but on a table with multiple columhns, it's a PITA. how can i change default to be sum?
Posted : 10/10/2013 12:29 pm
That normally means there's some non number values in those columns. If the content is sorted it will default to sum rather than count.
Posted : 10/10/2013 12:33 pm
From what I understand you cant change the default, but you can use an add-in to do it for you
http://www.contextures.com/xlPivotAddIn.html#!
monkfish wins a prize! Some zeroes weren't zero, but were blanks. Find and replace those and it seems to be fixed!
Posted : 10/10/2013 12:43 pm
