Community
excel oddness - imp...
[Closed] excel oddness - impress my work colleage.
I have assured the bloke on the next desk to me that STW can answer anything.
Spread sheets on his computer have started displaying a symbol which is a question mark inside a square box in text boxes that refer to spread sheet cells. My initial though was a zoom level issue, but it's not that. Not an automatic/manual calculation issue either.
All spread sheet on his laptop show the same problem, same files on my computer work fine.
Any ideas you IT geniuses?
Posted : 08/01/2018 11:01 am
Resize the boxes ๐Ÿ™‚
Posted : 08/01/2018 11:06 am
you both using the same version of excel,
dont think its this but worth asking.
does the sheet link to other worksheets in different drives and you have differing drive names
mr excel is sometimes usefull, not so sure today
https://www.mrexcel.com/forum/excel-questions/321197-excel-character-question-mark-box.html
Posted : 08/01/2018 11:08 am
Resize the boxes
Boxes don't change size between his and my computer, it's not that though.
Yes, same verisons of Excel and all the data is local on the same sheet of the same file.
edit - (following your edit!) I'm ashamed to say I tried Google before here, and that Mr Excel page came up for me too. Yeah, you're right, it's not quite the same.
our IT department are running the repair tool, I think they are grasping at straws and I'd like to solve it before they can!
Posted : 08/01/2018 11:10 am
Have you got the same add-ins selected?
I'm unclear about 'text boxes' I think you mean actual text boxes, rather than cells with text in them?
Posted : 08/01/2018 11:19 am
Screenshot?
Posted : 08/01/2018 11:20 am
Correct.
I'll check the add-ins once IT have failed. ๐Ÿ˜€
We have one in particular, (Pi) that has caused problems with Office 365, but I'm not sure he has that.
I'll try a screenshot later, but I think external image hoisting sites will be verboten.
Posted : 08/01/2018 11:22 am
Have you checked for any rogue Add-ins?
RM.
Posted : 08/01/2018 11:23 am
Fixed it. ๐Ÿ˜€
Changing the font from Calibri to Arial cured it. Still bloody peculiar though because all the text in the normal cells is Calibri, and at the same point size??!!
Posted : 08/01/2018 11:29 am
That is odd. Badly / non- installed font?
Posted : 08/01/2018 11:34 am
Not sure how a font can be badly installed, why would it work within cells, but not graphical (in this case text box) objects?
Posted : 08/01/2018 11:42 am
I think it just means it can't display that character as it's not defined in that font.
Posted : 08/01/2018 11:48 am
Character encoding issue at a guess, those weird ? in a box characters are used when the font you are using doesn't support some weird character or other, either because it is some obscure foreign/accented/emoji character or because someone has accidentally used a character that looks like a normal character but isn't (smart quotes instead of normal quote marks being the classic one)
Posted : 08/01/2018 11:49 am
Standard letters and numbers, which are referred from cells formatted in the same font and size. Like I say, very peculiar, but working now even though I don't understand the cause.
Thanks all.
Posted : 08/01/2018 1:24 pm
