espresso / coffee m...
[Closed] espresso / coffee making advice
I want 15b ar on the stove top godamnnit - over to the engineers...
Posted : 13/11/2010 9:27 pm
Are AeroPress coffee makers any good?
Posted : 13/11/2010 9:45 pm
They are excellent - no substitute for anything else, but great. I use one every day at work as it is better than anything else available.
Posted : 13/11/2010 9:59 pm
Has any one tried a [url= http://bit.ly/dg0Gl7 ]nespresso[/url] machine. My mate swears by his and it's idiot proof (his words)
Posted : 13/11/2010 11:02 pm
Aeropress does not make an espresso and it does not make filter coffee either but it does make a really clean, tasty cup indeed and for a quick easy portable way to have coffee cannot really be beat.
Two downsides though, it takes a lot of coffee to make a cup. Forget the 7-8 grams of an espresso, you need twice as much at least and for a mug dose well over 16-17. Second if you use it a lot (I use mine an average 3-4 times a day) over a period of a year and a bit it does not seal as well as in the beginning so you lose pressure and you can have coffee leaking up on the sides and also the filter holder develops a bit of a curve in the middle so you eventually get weaker coffee.
Having said that it costs as little as 17£ to replace.
Posted : 13/11/2010 11:09 pm
Nespresso is great. I bought one in August after a lot of thinking about what to get - stayed in a holiday place with one and was hooked. It is really convenient and makes very, very good coffee - seems wrong to me that something that easy can consistently make coffee that good. Sure, it's not the cheapest or most involving way to do things but for me it's ideal - to be honest I'm more interested in the outcome than the process.
Some people don't like it because it does takes the art away from making espresso and puts you in the hands of Nestle for all your bean needs, but with about 15 different blends it's hard to see how I'd tire of the choices available to me, and I don't think Nestle will dinghy it any time soon.
Posted : 13/11/2010 11:29 pm
 Pogo
Designed by Alfonso Bialetti in 1933, approx. 300 million have been made and 90% of Italian homes own one.
Just add
Posted : 13/11/2010 11:40 pm
I have a nespresso machines its brilliant and the coffee range is great, no mess and really quick to heat up. Highly recommended.
Posted : 13/11/2010 11:54 pm
Hi I would recommend a Rancilio Silvia and Rocky combination I have been using one for the last 10 years the Silva had a new boiler last year easy cheep diy Job. the grinder is way more important than the coffee machine you need to budget at least as much for the grinder as the machine. I would suggest you have a look at http://coffeegeek.com/ before you buy.
Regards Keith
Posted : 13/11/2010 11:55 pm
Job Done
Posted : 14/11/2010 12:36 am
nice naked portafilter and posh tamper.
Posted : 14/11/2010 12:55 am
I have no idea what you're doing there fella. 1.5 scoops of coffee will make a strong mug - just let the first fill filter through as you stir, top up the water then plunge. I've used mine about the same rate as yours for at least 2 years, a colleague a year longer and have no seal issues at all. The (tiny) curve in the filter holder makes about no difference as you plunge the coffee grounds onto it anyway.
Posted : 14/11/2010 8:33 am
 DrP
I'm nipping out for a starbucks.
Anyone coming?
DrP
Posted : 14/11/2010 10:05 am
so what's the general consensus on how to make a good cup of tea then?
Posted : 14/11/2010 12:14 pm
http://www.singletrackworld.com/forum/topic/what-is-the-best-teabag-tea
To summarise - Yorkshire tea.
Posted : 14/11/2010 1:08 pm
TooTall the scoop that comes with the aeropress is a 12gr scoop. If you use one and a half you are using exactly what I am suggesting - 18gr, that is well over two times as much coffee as you would use on an espresso maker. Even the maker recommends two scoops - 24-26gr for a 10 ounce mug.
Other than that I do nothing different than you, and I do have non sealing issues as well as the water coming only through the centre on my old aeropress while coming through the entire filter on my new one, so the curve in the middle is making a difference. Maybe my first Aeropress was a tad defective, I don't know, see how well the second one will do.
Posted : 14/11/2010 3:19 pm
Page 2 / 2
