Engineering part - ...
[Closed] Engineering part - does it exist? What's it called?
I thought this would be a simple thing to find - 12mm stainless rod, 175mm long, tapped M6 at either end. I can buy the blank stainless for pennies, but drilling and tapping 30 of them is beyond my equipment - I did get some made by a local engineering company for £25 each.
Does this exist? Thanks!
Posted : 02/11/2017 1:00 pm
It's called a Cooper Rod. It's named after the inventor.
There's a place near me that'll make them up as a special order for £25 each. 😉
Posted : 02/11/2017 1:06 pm
I would call that a female-female-standoff eg https://apexfasteners.com/fasteners/screw-machine-products/spacers-and-standoffs/standoffs/female-female-standoffs but I doubt you'll find one that large and especially that exact size off the shelf. Easy job for a chap with a lathe
Sounds quite specific - I think you're unlikely to find that specific length, that specific OD with that thread, or in stainless, in an off-the-shelf part. All 3? Slim to none.
Can you assemble it from standard parts? e.g. threaded bar cut to length, with threaded couplers, bushes and locknuts.
Cheers - I have a lathe and a tapping head, but drilling 60 holes in stainless makes me tempted to just pay the £25 each 😀
I hadn't thought of doing it with threaded rod and spacers, that's an interesting idea - I did consider 12mm tube with rivnuts in the ends, that's how I do some other parts.
Posted : 02/11/2017 1:11 pm
I can't see that being an off the shelf part, but I think the price is pretty steep, are there other places to get quotes.
How about buying tube with a nominal 5mm ID, tapping that, then sleeve over with some larger tube, a few tacks to hold them together or drill for some pocket welds if it needs to be more robust.
Well if it was a male part, it'd be called a stud; as for what the female equivalent of a stud is...
Anyhoo, think you might find something similar described as a tie rod.
Posted : 02/11/2017 1:14 pm
nickjb - Member
I am delighted that on that website there is something called a [url= https://apexfasteners.com/fasteners/sex-bolt?zenid=ddf12228442238f33cc9ec135b5e50fd ]'sex bolt'...[/url]
Posted : 02/11/2017 1:15 pm
I am delighted that on that website there is something called a 'sex bolt'...
I'm going to have to work out how to incorporate those into something now...
Posted : 02/11/2017 1:24 pm
A resolution - putting it here just in case anyone else needs such a thing:
https://uk.misumi-ec.com/vona2/detail/110302289370/
€17.53 each. and M8 threaded so not perfect. But promising.
Posted : 02/11/2017 1:32 pm
Can you find 12mm Ø with a 5mm hole? You would only need to tap them then..
I could see how much my place would charge to make them?
Posted : 02/11/2017 1:46 pm
This is interesting. I need something similar for a fork mod.
Posted : 02/11/2017 2:16 pm
Misumi are pretty good. You can customise lots of standard designs, change holes sizes, plate thickness etc and the prices aren't too bad. (Compered with getting it made locally.)
Posted : 02/11/2017 2:21 pm
