engine oil extracto...
[Closed] engine oil extractor?
prob a long shot, but does anyone have or used an oil extractor? i need one for an oil change on my boat, the pela 6000 is well rated on car sites but i see on ebay you can get similar looking ones for half the price.
Posted : 06/04/2009 4:47 pm
You mean like the pumps/siphons instead of letting it drain with gravity? "Apparently" it's standard on Mercs now.
Posted : 07/04/2009 12:34 am
I've had a sealey one for several years now, bought it when I rounded the sump plug on the wifes fiat.
Absolutely fantastic, I used it to suck the oil out of my car then took out the drain plug, no oil left at all.
Mine also has an attachment to bleed brakes.
Mine was £70ish and I'd definately buy another.
Posted : 07/04/2009 9:13 am
We just used a basic brass hand pump picked up at a boat jumble, empties the sump in 5 minutes of pumping.
Posted : 07/04/2009 3:10 pm
Ive used one on a boat with great success, make sure the oil is hot like you would on a car (typically drains one litre more when hot), and you have a suitable vessel to drain it into, esp when its hot.
I seem to remember it wasn't a particularly expensive model and worked well.
Posted : 07/04/2009 3:25 pm
I've got a Pela I use to change the oil on my car, absolutely brilliant and majorly hassle free, dunno about the eBay ones, but they're quite simple devices really and pay for themselves within a couple of oil changes.
Posted : 07/04/2009 3:29 pm
WTF?! You might get a few hundred ml more but a litre? The only difference hot oil makes is the rate it runs down the walls of the sump and engine at - assuming the engine was warm last time it ran it's going to have drained into the sump from warm then too!
my ebay one broke after 3 changes go for a manual brass one not much slower and impossible to break
Posted : 07/04/2009 3:30 pm
Coffeeking- if the engine is mega hot, and the sump capacity is big, you can get an extra litre out believe me.In am a keen car enthusiast and all the info in the magazines suggests so as well. In a smaller engine I agree is a few hundred ml. Modern oils are designed to stick to the engine components, and when cold they stick to everything, including the sump- so by having it hot you drain all that.
Posted : 08/04/2009 9:22 pm
I bought an eBay/crappy plastic hand pump for pumping out power steering fluid. It was shlte.
Posted : 09/04/2009 5:10 am
