Electricity questio...
[Closed] Electricity question
just bought a light from dealextreme (USA= 2pin, 120V)-
what adaptor will i need for use in the UK?
can find loads but none actually convert the voltage, which i presume i will need?
thanks
Posted : 06/01/2010 3:13 pm
 Pook
£2 shaver adapter from Tesco.
Posted : 06/01/2010 3:18 pm
My chargers from DX is a usa unit but it will do 110 to 220volts best you double check
A shaver adaptor is no use you need a USA to UK adaptor
Posted : 06/01/2010 3:21 pm
what salad dodger said
if it only does 120v (most are 110-260V) then it'd be easier to get a new adapter to match the output voltage/current/polarity
cool didnt realise chargers could cover dif voltages, fingers crossed the supplied charger will cope with 220V.
Posted : 06/01/2010 3:22 pm
output / current /voltage
na just a adaptor I got one from maplins for about £2
Posted : 06/01/2010 3:23 pm
yes
for instance you can get an adapter from maplins (other electrical retailers are available) that will match it, might be 9V DC, 300mA then the tip will normally be reversible for positive/negative
Posted : 06/01/2010 3:24 pm
ah ok, so if it is a 120V charger only--pick up a USA->Uk adaptor and problem solved?
Posted : 06/01/2010 3:28 pm
walla24 - Member
I wouldn't plug it in unless it ways you can.
The DX charger [with US pins] that I've just got is rated 110-240V
Posted : 06/01/2010 3:30 pm
put a link up to what charger you have and lets see what it is
this is the plug I was on about http://www.dealextreme.com/details.dx/sku.2709
Posted : 06/01/2010 3:33 pm
ah ha!
just had a zoom in of the adaptop[url= http://www.dealextreme.com/details.dx/sku.25149 ]here[/url] and it says 120-240V so should be all fine and dandy.
thanks for the help!
Posted : 06/01/2010 3:37 pm
yes thats what I have got, get a adaptor plug it in no worries
Posted : 06/01/2010 3:40 pm
