Electrical types - ...
[Closed] Electrical types - help me fix my lamp
I'm trying to fix a lamp but as a hammer doesn't appear to be the appropriate tool I'm a bit out of my depth. It's a halogen table lamp with a dimmer on/off switch and it just stopped working one day. Changed the bulbs, fuse in plug and all appears to be in order with the wires so I think it must be the dimmer/transformer unit at fault. Here's a photo of the label - can anyone tell me where I can get a replacement?
Posted : 05/12/2013 10:25 pm
The transformer has probably gone. Try a local electrical factors.Not sure where you are, but in Wales it would be LH Evans, Edmunsons, City Electrical Factors etc.
Posted : 05/12/2013 10:28 pm
Is it the kind of dimmer where you touch the base to turn the light on or move the dimmer up a notch? If so, it's very likely that the thyristor has failed. (Google touch lamp thyristor) It's not a big job to find it, get the number on it, buy a replacement and solder it in; I used a replacement with a higher current rating in the hope that it won't blow again.
Posted : 05/12/2013 10:46 pm
Ahh, the old funkentstorung!
Posted : 05/12/2013 10:58 pm
