i need 45 connectors for a project. I need the type of connector that a multi meter spike would fit into nicely...
you no the black and red connectors...
any ideas where to get some??
More info needed.
Maybe one of the Wago connectors would be good?
http://www.wagobox.com/shop/lever/
Are you just on about bullet crimps or something better than that? http://www.maplin.co.uk/insulated-crimp-terminal-bullet-plugs-42722?c=so&u=strat15
Black & red, 4mm banana plugs spring to mind, but only really useful for going onto terminals:
http://www.rapidonline.com/productinfo.aspx?tier1=Cables+%26+Connectors&tier2=Connectors+-+Single+Pole&tier3=4mm+Connectors&tier4=4mm+Stackable+test+plug+screw+terminations&moduleno=125052&catRef=17-2885
Maplin
thanks for input guys...
also Parraell ATA cable and 2 Sockets without a motherboard??
would be great.
maplin are stupidly expensive
http://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalspreins/preinsterms.php
Maplin are expensive, but at least you can figure out what prefer by handling them.
RS have a good range, or try CPC
