MM - you are a pro though 🙂
Oh btw I tried converting my RAWs to DNG but DXO wouldn't open them either. Seems its DNG support is limited to saving them..?
Seems you can request support (though how much difference it'll make, who knows).
http://www.dxo.com/intl/photo/support/modules/availability/pb_availability
it IS supposed to be a raw processor, and goodness knows what liberties Adobe may take in writing a DNG...
They shouldn't be taking any. The point of DNG is simply a common RAW standard, isn't it?
as invented by Adobe...
Yes. Adobe who are not a camera manufacturer.
They have good form in this respect - making industry standards.
Re UV/Skylight filter for "protecting the lens".
Big waste of money IMO. It just adds an extra layer of glass on top of all your pictures, degrading the picture quality for no very good reason. If you use your lens hood you will protect the lens from most sources of damage and avoid reducing your image quality.
I read a waffly article yesterday that said much the same thing. In summary; it was good advice ten years ago. These days lenses are made of pretty strong stuff, filters can introduce ghosting, and a small blemish on the lens will be unnoticeable anyway (the example cited here was to put a bit of Post-it the size of a pea on the lens and then look through it).
Apologies in advance if this is incorrect as I'm simply a newbie with Google, but,
I don't believe those shots would demonstrate the problem. The issue comes with shots with hot-spots of bright light, you can get a diametrically opposite ghost 'flare' effect (eg, if you have a street lamp at 11 o'clock in the image, you'll see a flare at 5 o'clock equidistant from the centre).
Ah, here, this is the article I'm referring to (with example pictures).
http://www.luminous-landscape.com/columns/sm-feb-05.shtml
There's a couple of possible problems. One is degradation because there's an extra layer of glass. The other is extra layer causing flare.
The above image gives you an idea of the size of the first problem.
As far as flare goes a decent filter will be a similar order of magnitude. I don't have any back-to-back tests but I don't have flare as a problem when I use filters.
Without a doubt filters degrade image quality but unless you print poster size and the look for problems you won't find any.* Even then other factors are far more likely to be a problem.
Don't forget that you'll get flare without a filter too. Everything is relative (no filter on this one):
*with good filter, the vast majority of the time
Well quite. You can take things too far, the audiophile world is similar.
But the point is that an audiophile spends cash for a (perceived) better sound, whereas here the photographer spends cash for a (perceived) degraded image.
The OP was short of money - so I suggest that using resources on buying a filter is not a good idea.
Not quite where I was going.
There's an argument in the audio world that every piece of equipment, every circuit, every process that the signal goes through, degrades the sound. It's probably true, but the question is, does it degrade it perceptibly? (and how about cumulatively?)
Same thing. You're shooting through an extra pane of glass. Does it degrade the image? Almost certainly, yes, but is that of any consequence whatsoever?
Yeah, that's a good point. I could buy a pretty good used lens for the price of a decent filter.
Consequence to whom? Probably not to the majority of people. But to restate my point:
Filters:
negative - cost a lot of money for a good one, degrade image (with caveat as above)
positive - provide marginal protection to something that probably doesn't need protecting
I'm not disagreeing.
I'm also, oddly, well versed as to where the OP was coming from. (-:
A handy hint I thought about today: consider a wrist strap instead of the lanyard you get with your camera. I tend to walk around with my camera in a shoulder case or small bag (like the one I am sending you). Getting the camera out and untangling the strap and then retangling it was a bit of a pain, but also walking around with the camera around my neck was annoying me since I then had two thigns around my neck. So I realised that a wrist strap would be much more convenient and still protect my camera against being dropped. €8 later and my 'workflow' is significantly improved, faffage is reduced.
Plus (this relates to the previous topic) when my camera is not around my neck it doesn't swing forward and hit things when I bend over, which was a major risk of smacking the lens.
Re flare once taking pics indoors I noticed horrible ghosting and flare. Holy crap my lens is rubbish I thought, until I took off the filter.
I had another great tip but I've forgotten it 🙁
I've never used a neck strap before, and I am finding it horribly, uh, horrible. Room for improvement certainly. I can't seem to work out which part of of my torso it should be bouncing around uncomfortably against.
Yeah with mine I put one arm through it and put on my hip, but then it's not long enough to comfortably swing round the front to use. Definitely try a wrist strap, big improvement for me.
Now what else was I gonna say? Dammit.
So a pea-sized piece of paper is unnoticeable, but a clear filter will degrade the image?
Just bought one of these for about a tenner posted, looks good for the money
[url= http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130509584481 ]QuickStrap[/url]
reviewed here
(preview doesn't seem to be working)
Good point. I'm going to replace the mirror in my shaving kit with a Post-it, just as effective and takes up far less room.
[url= http://kurtmunger.com/dirty_lens_articleid35.html ]This[/url] is quite interesting (crap/scratches on lens experiment).
There's one where they show some pictures. One looking basically fine, another with a few blemishes, then they show you the lens which has the front element completely smashed.
That's the one.
No, it's not - it was a different one. I found that when trying to search for the original article 🙂
