driving and the use...
[Closed] driving and the use of brakes
48 Users
 mrmo
Out of interest, just wondering if people tend to let the car slow in gear or hit the brakes when they approach junctions, queueing traffic etc.
Posted : 07/11/2011 7:32 pm
I was always a confirmed "engine-braker" (must be my motorcycling background) but during advanced car driving instruction I was convinced that it's cheaper to replace brakes than engines 🙂
In reality, I try to ease off before I have to stop - so "none of the above".
Posted : 07/11/2011 7:33 pm
I sometimes amuse myself by seeing how far I can drive without touching the brakes. Bad for the engine ? could be, but I've never heard that one before.
Posted : 07/11/2011 7:38 pm
nothing worse than a brake happy guy on the motorway, tapping his brake every few minutes, instead of just leaving a bit more room
Posted : 07/11/2011 7:39 pm
I normally plan to use the engine to slow down and only use the brakes towards the end of the deceleration unless it transpires that i misread the situation. Only do it because I think it flows a bit smoother.
Not to say that my way is right or wrong, that's just how I drive.
Posted : 07/11/2011 7:47 pm
Jackie Stewart's book Principles of Performance Driving.
Chapter 4
The High Speed Technique.
"On the subject of gear changing techniques, I have always believed that you should take as little out of the car's transmission as possible that obviously means gentle, sympathetic changes when going up through the gears, but also by using the brakes to their maximum when slowing down, often missing gears while changing down through the box. Many people think that racing drivers go all the way down through the gears in a six-speed box like a machine gun. But that means you're taking on a juggling act: steering, operating the pedals, blipping the throttle and using the gear lever like a madman. I always chose to change down by jumping through gears.
........from sixth to fourth to second. That applies to wet or dry conditions, although you need to be careful how you do it in the wet, perhaps eliminating all the down changes, using the brakes to knock off your speed, and then finally slipping from sixth to first gear right at the end. Remember, you are not going to stop any faster by using the transmission. Brakes are made to stop a car, gears are primarily for acceleration. Deceleration was not part of the gearbox's original purpose: don't abuse it. "
Then again he was only F1 world champion 3 times.
Posted : 07/11/2011 7:48 pm
its only bad for your clutch if you down shift to slow down. pre emptive slowing down in the same gear is fine for the engine/clutch.
I still only use my brakes.
Posted : 07/11/2011 7:49 pm
Around town, use the brakes - better to have some lights come on to give those behind a chance of knowing what you're up to. Hasn't stopped 3 folks running into the back of me tho... 🙄
Posted : 07/11/2011 7:51 pm
 hels
Not sure I would take Jackie Stewart's advice on anything - have you seen his trousers ?? Not to mention his hair...
I engine brake it's how I was taught to drive - I vaguely remember something about better control when the engine is powered rather than coasting. Try to keep it smooth rather than jumping on the brakes, keep a good distance and you don't need to.
Oh yes and of course tap to show some brake lights when slowing down, esp on the motorbike.
Posted : 07/11/2011 7:56 pm
 hels
I beg to differ on bad for the clutch - drove the same van for 100k miles on the same clutch. Sample of one, I know.
Posted : 07/11/2011 7:58 pm
Interesting that stuff from Jackie Stewert - I was taught to engine brake and always do - but tend to touch the brake pedal very lightly to illuminate the brake lights.
So say coming towards a roundabout on a 60 mph road I would double declutch down at least one gear at relatively high revs and then slow in that gear
Interesting
Posted : 07/11/2011 7:59 pm
 juan
That's because like me TJ you're a two-wheeler. going hi-revs actually give yo more stability. Very noticeable on a 2 wheeler, not so much on a 2 tons box of steel with 4 wheels.
Posted : 07/11/2011 8:06 pm
I've always used the engine and gearbox instead of the brakes, especially in snow or icy conditions, but that's mainly open road driving; in slower traffic I use the brakes, and coming up to junctions or whatever I use the gearbox to shed speed then use the brakes for final slowdown. It works for me, I've only had a car go sideways once on a very icy road.
But then, I'm not a racing driver, and don't try to drive like one.
Posted : 07/11/2011 8:07 pm
I normally lift of the accelerator and slow down before using the brakes. I don't deliberately shift down to slow down.
My driving instructor always told me that you shouldn't need to do anything other than gentle braking (except in an emergency) as you will be looking ahead and thinking about what is going on and what you are needed to do.
Don't understand playstation drivers (only have go and stop) who floor it away from lights then brake hard at the next set. Maybe its the cycling influence, I'm reluctant to sprint away from lights and then brake when I can go a bit slower and not have to stop conserving energy).
Posted : 07/11/2011 8:08 pm
Start thinking of brake lights as signals and you'll soon stop engine braking.
Back in the days of all round drum brakes that couldnt self adjust people used to be taught to engine brake, because if they didnt the car would always be in the garage getting the brakes adjusted. Now in the days of cars with all round disc brakes and everything self adjusting, that need has been taken out and transmission is the most expensive part to replace. There are also a shed load more cars on the roads so please tell each other what you're intending to do....
Posted : 07/11/2011 8:09 pm
Macavity - Member
Hmmm, performance driving so not that relevant to driving around on the roads unless your some rude boy trying to race round every corner up and down through the gears.
Posted : 07/11/2011 8:16 pm
Brakes to slow gears to go (so no changing down to slow down), but there was also a big emphasis on what they called 'acceleration sense' when I did my training, which I assume still applies. ([url= http://www.approved-driving-instructor-training.co.uk/speed-and-gear.php ]Good description of it here.[/url])
 hels
Brake lights as signals - of course they are, what numpty wouldn't adjust their speed when the car in front of them does. Not convinced that precludes engine braking - esp if you keep a good stopping distance and know what is behind you, as you know what mirrors are for. Nobody exclusively engine brakes that would be silly, slow it down then the brakes for the final approach.
Unless some eejit is following too close, then they get a few wee taps to make him back off.
Posted : 07/11/2011 8:20 pm
That's not quite my point. It's easier to notice a car slowing down due to brake lights than it is due to it getting closer. Some people who are perfectly capable of driving only have good eyesight in one eye so arent all that great at judging distances.
Posted : 07/11/2011 8:23 pm
Where's Smurfrat when you really need him?
Posted : 07/11/2011 8:26 pm
I was told not to engine brake on my minbus-for-schools training.
One of the things that crossed my mind (apart from slowing a vehicle full of someone else's kids with no braking signal!) was that an empty long wheel base transit (with therefore a much greater proprtion of its overall weight near the front, but still with driving wheels at the back) using its rear wheels not front ones to brake was a potential recipe for slidy back end on the minibus, and brown trousers on its driver.
Mind you, quitea few years since then: are new trannys fwd now?
Posted : 07/11/2011 8:28 pm
Engine breaking when I was doing my police advanced driving training was an automatic fail. Unless you were doing it to aid in winter type conditions to help with gradual breaking.
Posted : 07/11/2011 8:29 pm
I think is a generational thing. My old man always uses engine braking slowing down where as I have always used the brakes because I was also taught that it is cheaper to replace brake pads than it is a new clutch.
Posted : 07/11/2011 8:34 pm
Just for clarification, because I remember this getting argued about before.
When people say engine braking are they talking about
1) Lifting off the throttle and allowing the car to slow down as described in that link up there, or
2) Changing down a gear to slow down?
Because they aren't the same thing (a policeman told me the first is ok and the second is not).
Posted : 07/11/2011 8:35 pm
I tend to change gear to slow down - so approaching a roundabout at 60 mph the first thing I will do is double declutch down a gear or even two.
Not saying its right but thats what I do.
Drac - thats interesting - I got as far as doing my driving assessment for the ambulance service and they asked me to change down a gear at 50 mph without jolting the vheicle
Posted : 07/11/2011 8:48 pm
I was talking about number 2
Posted : 07/11/2011 8:49 pm
That would be a sustained gear change, to smoothly (and therefore stably) select a more appropriate gear, not to slow down.
Posted : 07/11/2011 8:54 pm
I'm trying to work out what you would be driving/riding to need to do that?
I was taught the same as Drac on my driving course but in reality I do use engine braking to some extent when driving at speed (particularly if it's icy or in snow) and will also on occasion go directly from 5th to 1st depending on circumstances and conditions.
Woody - anything I drive ( not that I drive a great deal these days) Its just my habit to use the engine to slow and to drop down the gears at high revs. as Juan says it might be habit from motorcycles. 60 mph in 3rd is still way off the redline in most vehicles.
Its about having he engine in its most responsive range and having it in the right gear to accelerate away
I even heel and toe downshifts sometimes if I want to change down further while braking.
As I say - I accept thqt it might be wrong / outdated practice. I did do a lot of miles on old british bikes with rubbish brakes
Posted : 07/11/2011 9:00 pm
TJ - that's not double de-clutching 😉
Posted : 07/11/2011 9:06 pm
More of Jackie Stewart
Chapter 6
"The Road Application.
Somehow many people think that the better the driver you are, the more gear changes you need to make, both up and down, not to mention changing down as many times as possible when you are braking for a stop sign or a round about. Not so! I'd rather use the brakes first because brake pads are cheaper to replace than gear boxes!
Roll into a corner under braking, even in fourth gear, and put it directly into second gear when the time is right, but not when the car is going to nose down and the rear wheels lock up momentarily while the revs shoot off the clock.
So don't rev the engine violently; change gear early and apply the brakes before down-shift smoothly. The braking comes before the gear changing on the way down, never the other way round. And the brake application again should be smooth and progressive. Before you have even so much as touched the brakes you must consider the way in which you come off the power. Don't come off the throtle pedal abruptly, but ease back on it gently.......
The same should apply when you press the brake. Do it gently and progressively and , before you have finished the braking motion, release the brake again very gently and progressivley, so that you don't feel it coming off.
.....a road car is more softly sprung and greater suspension movement , more roll, more dive and more squat. All the movements are exaggerated compared with a competition car."
The style of driving that only got JS 3 world titles was to be as economical and as smooth as possible. This was to use as little fuel as possible and to have as much control as possible. It was a style of driving that JS beleives is directly transferable to road driving.
As JS says there are no principles / techniques that he used that are different from the ones that he would use in normal road driving.
He also has an example of how his team mate Francios Cevert died in a crash; possibly by being in too low a gear, with the revs too high and lost control of the car.
The advantages of driving as the car was designed , using the brakes are many: all four wheels are breaking (sharing the tyre wear in a two wheel-drive car at least), Dual Mass fly wheels are not cheap, etc.
Posted : 08/11/2011 6:15 am
Double declutching, are you 85 TJ? Out of interest and for balance, have you noticed a higher proportion of maintenance bills on your vehicles or not?
Posted : 08/11/2011 7:02 am
Oh and my cars DSG so it does it's own thing
Posted : 08/11/2011 7:08 am
I guess if you take it down just the one gear to allow a gradual decelleration to continue to progress, without kicking the engine too high in the rev band, then it's not much of a problem, and you have more braking available if you need to come to a halt more quickly. In these situations I always have my foot on the brake pedal just a little to make sure the brake lights are on when doing this.
Posted : 08/11/2011 7:27 am
Woody - proper double declutching and heel and toe downshifts
M6TTF - I don't own cars - hire cars / vans so no idea if I am causing more wear.
I was definitely taught to use engine braking. but it was 30 odd years ago.
Posted : 08/11/2011 7:29 am
[u][b]Engine Braking[/b][/u] is where you leave it in a gear to use the engine's internal friction in order to slow the vehicle. On most cars this is perfectly fine and will not ruin your engine, load paths are reversed due to the direction of torque inverting, but this is factored into the design of all transmission components.
[b][u]Transmission Braking[/u][/b] is where you shift down through gears to keep engine speeds higher and therefore frictional losses higher, therefore slowing the car down faster. If you need to slow the car down faster than engine braking in one gear provides, use the brakes. Transmission braking puts large spikes of torsional vibration through the drivetrain, leading to shock loading of components (especially gear teeth with high contact pressures), and if repeated regularly will knacker some gearboxes and differentials. This may be less of an issue on modern cars, however if I was driving a car hard I still wouldn't do it, unnecessary.
My personal driving style when aiming for fuel economy is to try and judge every traffic light/roundabout/obstacle as a prediction, to try and get the car to roll to a near stop. It does help that I tend to drive when the roads are quiet, reducing me pissing off other drivers. I will still do it when roads are busy, just not to the same extent. It also can add fun into roundabouts on quiet days, attempting to not use brakes 😉
Posted : 08/11/2011 7:48 am
You have to brake in my car but then its an auto plus its also a diesel and they have next to no engine braking when lifting off as they don't generate a vaccum on the intake like a petrol engine. This is why you will catch up with a petrol car who has lifted off even though your are not pressing a pedal.
Smooth is the key and that includes braking and its not like pads don't last a long time in cars.
Posted : 08/11/2011 7:58 am
You can tell who the old people are on here 🙂
Back in the day when cars had drum brakes people were advised to use engine braking as brakes were a bit useless.
These days you should be taught to use the brakes and not gears to slow down (because they do a much better job than the engine, and avoids wear on the clutch etc), its what the Police do etc.
Double de-clutching is actually a waste of time in a modern car because of the syncro mech. Very satisfying if you get it right, but a waste of time..
The one thing I didnt know until a few years back was to actually leave the car in gear though for 2 reasons. Firstly it saves fuel, and if you are involved in a crash and foot comes off the brake pedal, then the engine will do some braking.
Fast driving/track/rally driving is different all together.
Posted : 08/11/2011 7:59 am
Engine [b]breaking[/b] when I was doing my police advanced driving training was an automatic fail.
I should think so too! 😉
Posted : 08/11/2011 8:02 am
Just remember Jackie doesn't have a driving license and never has had one (if I recall correctly). All his (legal) driving has been on the track.
Posted : 08/11/2011 8:09 am
Brakes to slow, gears to go! The only reason racers downshift the way they do is so that they are in the right gear to accelerate hard out of the next corner.
Double declutching - clutch down, gears into neutral, clutch up, blip the throttle, clutch down, into next gear, accelerate.
Totally poinless on a synchro mesh gearbox. Its only usefull on a crash box, the clutch up in neutral blip the throttle bit gets the lay shaft ( i think) up to the same speed as the main shaft so that the gears mesh smoothly.
Posted : 08/11/2011 8:14 am
I look at braking as a waste of energy, you're converting the fuel you've just used to accelerate into heat at the brake pads. Accelerate less, look ahead and match your speed to the conditions. If you see the traffic slowing up ahead, ease off the throttle, so many people seem to tear up to a red traffic light and slam the brakes on at the last minute.
Posted : 08/11/2011 8:30 am
What utter tosh, who told you that? Like for like, a diesel engine produces far more engine braking, due to the much higher compression ratio. The reason you have to brake in your car is all to do with the autobox, not the engine.
Posted : 08/11/2011 11:23 am
Errrr, no? Sory t omake you sound a bit thick but think about what the compression ratio is
a) there to achieve
b) how it is achieved
c) where all the energy used compressing the air goes when the piston goes down again.
Part of the reasons why diesel is so effiient is the engine doesnt have to suck air through a restriction, it always gets a full cylinder (or more in a turbo) of air. When you close the 'throttle', which doesnt realy exist, there isnt anything to throttle [i.e. in the litteral cense contract/restrict the opeining] on a diesel, all it does is stop the fuel. The engine therefore takes a full charge or air, squashes it and recovers most of that energy when it expands again.
A petrol engine when the throttle is closes pulls on a prety high vacum (the throttle has closed off the air supply) so it does a lot of work drawing anyth air in, this warms up so the energy recovered sucking the piston up again is less than that used to draw it into the cylinder.
To get arroudn this some old diesels have whats called a jake brake which raises the decompression cam at th top of the compression stroke on the on a diesel to let the air out and stop the energy being recovered. These were banned as they sound like a machine gun.
Posted : 08/11/2011 11:40 am
 goon
Slight hijack, but, when you've actually stopped (and I'm addressing the seeming majority of drivers here) could you release the brakes and let the lights go out. Put the handbrake on if you are going to be stopped for oooh, I don't know, more than a second. They are amazingly dazzling up close in the dark, especially on a crowded dual carriageway, and mask the brake lights of others who are still slowing.
Posted : 08/11/2011 11:47 am
Almost, its the input shaft that needs spinning up to speed again (the bit that's atached to the clutch.
Imagine it in 3 parts, engine, gearbox input, gearbox output. the output always spins at the speed of the rear wheel, the engine is the engine and the input shaft conects the engine and the gearbox, the gearlever connects the input to the output, you could infact achieve a pretty similar effect by bolting the gearbox straight to the engine and putting the clutch between the box and the axle, but it makes sense doing it the other way as the flyhweel the cluch pushes against is on the back of the engine.
Double clutching does nothing more than wear out the clutch reslease bearing on a modern car.
Posted : 08/11/2011 11:50 am
A friend once drove from Knaresborough to York and back (about 28 miles) with no brakes.
And I mean no shoes on the drums at all. All round.
He was a silly boy but managed it.
Posted : 08/11/2011 11:52 am
I do not think that is true. There is certainly a lot of engine braking on every diesel I have driven. More than in petrols at similar revs I would say.
Posted : 08/11/2011 11:56 am
 will
I was taught to use engine braking (change down the gears to slow down)as you car is in more control.
Since then (5 years) I have always used engine braking. It always used to really annoy me when I was in the car with the mrs and she used to not use the gears, on the brakes all the way, then slam it into 1st whilst the car is still moving 🙄
Posted : 08/11/2011 11:59 am
Even wiki agrees with me
http://en.wikipedia.org/wiki/Jake_brake
Although it does imply that they might be fitted to engines now so maybe modern diesels do have them.
On the original topic I leave it in whatever gear I'm in and coast allong untill I have to use the brake pedal to stop. No need to shift down unless it's a big hill and you need to be in 1st/2nd to keep the speed under controll.
Posted : 08/11/2011 12:06 pm
well, given that i failed my first driving test attempt for accruing 5 minors for depressing the clutch pedal too early when braking i now use the transmission to brake all the time in conjuction with using the brake pedal.
Posted : 08/11/2011 12:08 pm
How about blipping the throttle on a normal downshift to match revs? I've done it for the past few years to make progress smoother. Is that bad for the clutch/gearbox/engine?
Posted : 08/11/2011 12:11 pm
Tinas - if I am in first or second in my car and I lift off at higher revs, I get jerked forwards because of the amount of engine braking. There's no machine gun sound. All the diesels I have driven from old 80s designs to modern CRs have done the same thing.
Your explanation sounds very reasonable but it doens't seem to match experimentation.
Posted : 08/11/2011 12:13 pm
 br
It'll depend on your age and what you are driving/riding.
I was taught (car) to slow down using brakes and then select the correct gear needed.
I was also taught (m/c) to be in the correct gear at all times.
I still do both, although auto in a car for years now.
Posted : 08/11/2011 12:15 pm
Maybe turbo's have a similar effect, once the fuel stops and the turbo stops spining it would act as a restriction like a petrol engines throttle?
Posted : 08/11/2011 12:17 pm
Yeah they fault you if you cruise too far with the clutch down, as you are not in proper control of the vehicle.
Doesn't mean you have to transmission brake though.
Posted : 08/11/2011 12:18 pm
Re: age.
I learnt to drive in, oh, 1990-91 maybe? And I was taught to block change down - ie, brake to scrub speed, and dip the clutch at the last moment before it 'chugs' to stop it stalling, going straight from 4th/5th etc to 1st/2nd. I think it was a relatively new thing at that time.
In practice, I'll slow on the brakes but step down through some gears (maybe 6-3-2), not at high revs to transmission-brake, but at moderate RPM in readiness for a change in conditions such as traffic lights changing.
That's called coasting, that's different. You are (arguably) not in full control of the vehicle. You don't have to slam it in second at 50mph in order just to keep the engine engaged.
Posted : 08/11/2011 12:26 pm
Those of us taught to drive years ago were conditioned to move our way up and down the gear box systematically – 4, 3, 2 and 1. But that’s because vehicles in those days had inferior brakes and we needed to bring the cars to a halt by using the drag of the transmission.
These days, we recommend “block changing”. Use the brakes to slow down, then, when the speed is right, choose the gear that is best for that speed. So you may move from fourth, say, straight to second, after you have finished braking. Brake pads are cheaper to replace than clutches. You can also block change to move up, skipping intermediate gears. So remember “gears to go, brakes to slow”.
So say the Institute of Advanced Motorists. Who are probably wrong if we ask the double declutching TJ 🙄
Tinas - perhaps, yes. I'd think that the restriction of the turbo's exhaust turbine would be much more though.
There's also possibily something thermodynamic going on - high compression would heat up the intake air a lot, and then some of that head ends up in the cooling system so you get less back on the expansion stroke. Double the compression would result in much more heat leaving the intake charge.
Posted : 08/11/2011 12:29 pm
Tinas. Interesting theory. But unfortunately, nonsense. Maybe it would work on a conveyer belt? The problem with your theory is;
A) under engine braking conditions little/no combustion is taking place, so no 'energy recovery', in fact greater energy required to turn engine compared to a low compression petrol engine, which is obtained from the kinetic energy of the vehicle via the drive train. Just try turning a diesel engine Over by hand compared to a petrol one.
B) the main reason that diesels [i]Seem[/i] more efficient in comparison to petrols is that diesel as a fuel is a heavier and therefor more calorifically (sp?) dense fuel. If we measured fuel by mass rather than by volume it would be a different story.
All engines are basically compressors, powered by the ignition stroke. When that ignition isn't happening, either when turning over in a no fuel state or on the over run in a low fuel state, the resistance (engine braking) is proportional to the compression ratio. Try driving down a 1:1 slope utilising only engine breaking in a diesel vs a petrol landy and you will know I am right.
Source: many years of messing around with both petrol and diesel engines, mainly in landrovers.
Sorry to make you feel a bit thick like, but every day is a school day...
Posted : 08/11/2011 12:31 pm
the main reason that diesels Seem more efficient in comparison to petrols is that diesel as a fuel is a heavier and therefor more calorifically (sp?) dense fuel. If we measured fuel by mass rather than by volume it would be a different story.
No it wouldn't, not by much anyway, given a high enough compression ratio you could build a 'diesel' to run on petrol and it would still beet the normal petrole engine.
Yes diesels have higher compression, but that compression then pushes the piston down the far side, otherwise air sprung forks would never rebound in your theory.
No they're not, a compressor would open the inlet valve on the downstroke, then the exhaust valve on the upstroke, thus it's being forced to do work on the air on both strokes. In an engine the compression and combustion strokes take place in a sealed cylinder, so in a diesel it recoveres (a large proportion of) the energy contained in the compressed gas, the inlet and exhaust stokes are comapratively work free. In a petrol engine the engine braking is done by the inlet stroke sucking against he manifold vacum which is sealed by the throttle butterflys being a tight fit with the manifiold.
source: designing stuff with much bigger pressures than a diesel engine for a living.
My focus quite happily crawls down 1in3's in 1st.
Posted : 08/11/2011 12:55 pm
Engine braking is all braking effects from the engine. Basically any drag is a braking effect. I agree that your explanation of the intake restriction and its effects. However, there are many other effects. First, a petrol engine
is still burning fuel. The amount of fuel and air in the cylinder is still close to ideal. Point being that it still produces power. The engine does breath quite a bit still. Sure, a diesel uses some fuel too but it is extremely small b/c the inj. pump goes to idle settings off throttle. Another point is that the compression of the air on the up stroke and expansion (air spring) is not adiabatic and is a function of compression ratio. Hence, higher compression does add a significant braking effect. Remember we are almost talking 3x here. Diesels take quite a bit of energy to keep spinning.
What's your focus got to do with it? Comparing like for like, 2.5 diesel (turbo or otherwise, doesn't seem to matter) vs 2.5 petrol in a vehicle of the same weight, with the same gear ratio with the same flippin engine block, the diesel has WAY more engine braking. Real life bud, sorry.
From an aussie 4x4 site, this seems to sum it up;
Engine Braking
Another distinct advantage of the diesel engine is its engine braking. The design of the diesel engine means that it sucks in air unrestricted and the amount of diesel fuel injected determines how much power the engine makes. A petrol engine requires a constant fuel/air ratio so the amount of air drawn in by the engine is regulated by an inlet buterfly in ratio to the fuel being used. What this means is that at idle, a diesel engine still draws in a large amount of air (RPM x engine capacity) while a petrol has the butterfly almost closed and there is very little air being drawn in.
When using  engine compression for downhill braking and  factoring in the compression ratio of 20:1 for a diesel and only 9:1 for a petrol, the diesel engine offers significantly greater resistance to an increase in engine RPM.  The diesel engine offers significant resistance as large quantities of air are still being drawn in through the unrestricted air intake and being compressed to 20:1. The petrol engine has the air intake butterfly closed during downhill braking and so only minimal quantities of air is being drawn in and then, its only being compressed to 9:1. This is why a petrol engine tends to "run away" compared to a diesel.
Also, it's a bit daft to state that the engine braking effect from a petrol engine is due to the vacuum formed in the inlet manifold behind a closed throttle. Imagine how strong the throttle butterfly would have to be built if it was going to accept the braking forces of a large vehicle slowing from a significant velocity. My money is on compression ratio, sorry.
Posted : 08/11/2011 1:10 pm
I didn't say they were perfect compressors, I said they were basically compressors. If you were to drive an engine via its output shaft and connect a pressure vessel to the exhaust, it would compress air. Not as efficiently as a two stroke compressor, granted, due to two strokes being redundant.
Well lets hope you understand that stuff better then... 😯
Posted : 08/11/2011 3:57 pm
Engine overrun.
Posted : 08/11/2011 4:11 pm
I do that on my Ducati simply because it sounds awesome! Does't harm the engine or box but will use more fuel.
I've done a few trackdays though and i found i was a lot faster when i stuck to the gears to go brakes to slow idea. Most racing bikes will have a slipper clutch these days which allows you to change down as fast as you want without worrying about blipping the throttle or locking the back wheel. All they are changing down for it to be in the right gear to accelerate out of the corner.
Posted : 08/11/2011 4:21 pm
Ok how about a 1.9 diesel manual and a 2.0 petrol manual. I know which on produces engine braking also all morden cars controlled by the ecu cut fuel on a closed throttle above a set rev level. He'll my 1986 205 gti used to do this and if you did an emergency stop the engine cut out.
Posted : 08/11/2011 4:31 pm
not really a fair comparison, gear ratios will be totally different to allow for the roughly 40% lower redline in the diesel. Although my 1.9 Peugeot noticeably has a LOT more engine braking than a similar petrol.
Your 206 gti kinda proves my point actually, high compression (for a petrol) and low gear ratios (which modern diesels dont have, lessening the noticability of engine braking) means lots of engine braking when not being fuelled.
Posted : 08/11/2011 8:21 pm
A friend pointed out to me about 5 years after i passed my test to blip the throttle and i could go down through the gears smoothly.Ive always done it since. Couldnt get the knack of it at first but its here to stay. Ive never fekked a clutch,gearbox or engine. One car i had done around 130k in it, the wee 106 diesel i had done 120k in it (around 160k before it was sold with original gearbox and clutch)the current diesel i have is now on 216k (got it with 23k on the clock) and the gearbox feels like new,never had a clutch. The other car,a 106 gti, ive put 80k on it and blipped the throttle to death down through the gears.. its due to blow up but never seems to. I glance at the rev counter when i blip and know where to blip it to for 4th 3rd and rarely 2nd.Blipping into 1st on that car no matter how well the revs were matched would put me through the screen face first down the bonnet! That car is still on the original gear box too. I`d never stop doing it.
Posted : 08/11/2011 8:37 pm
Same as people say above. I'm old so I learnt to to engine brake. But had a couple of lessons with advanced driving instructors in the last few years, and it is clear that the methods taught have changed.
Posted : 08/11/2011 8:42 pm
Even with a good well matched "blip" on the bike.. ive read (some top kawasaki engine expert) that the stresses it puts through the gearbox is not good at all.He reconed you would eventually thrash it to death on the bike.
I dont mind doing it on my cars that are worth around £300 & £900. Besides,they will die of some other problem long before one caused by a blipping gone bad!
Posted : 08/11/2011 8:44 pm
I tend to only "engine brake" in a low gear when going down hills and trying to hold the car back without needing to brake. I try to anticipate speeds and minimise braking. Braking is a waste of fuel, but sometimes it can't be helped 😀
Posted : 08/11/2011 8:47 pm
A STWer yesterday...
Wheres the flower?!
Posted : 08/11/2011 8:54 pm
I'm surprised that gearboxes can handle the stresses of harsh acceleration with aplomb, but not the stresses of deceleration. Unless you're dumping the clutch at redline revs, I'm struggling to see how engine breaking can be any worse than vigorous driving.
Posted : 08/11/2011 9:19 pm
Ah yes... the air charge drawn into a petrol engine under almost closed throttle will be very low pressure, so the piston will be sucked up instead of working against atmospheric pressure. What's the actual inlet manifold pressure differential?
On the subject of compressors, it has occurred to me that a diesel compressing the same amount of air all the time is very wasteful considering it only uses a little bit of that air. So it would be muc more efficient to have a small V8 and under normal driving leave one side of it unused and leave the valves open, so you're not compressing any air. Large American petrol trucks do this so the tech exists.
Posted : 08/11/2011 9:20 pm
Never seen the words V8 and efficient used in the same sentence before, unless 'not' is in there too... Lol! I'm pretty sure some big eighties American saloon cars did the deactivating of cylinders thing, (not one bank, that would be horrible, the front four I think) but I don't think it caught on. Good idea in principle but complicated in execution, you need separate camshafts for the valves of the cylinders that will be deactivated and the engine needs to be configured in such a way as when running on less cylinders it isn't horribly out of balance.
Posted : 08/11/2011 9:31 pm
It has caught on in the trucks. And the reason for de-activating one bank is that it's far easier to do - just have a clutch on one of the cam pulleys I suppose.
Anyway I am talking about a 2.0l V8, say, which would give normal performance and good economy.
Posted : 08/11/2011 9:57 pm
 Olly
close but not quite. the machine gun noise has to be silenced, but lorries still have Jake brakes.
Of course diesels have engine braking. anyone who lets off the accelerator in any diesel vehicle knows that. but its not the same as a petrol, where the braking is naturally through the throttle. it is "artificially induced" through either a throttle on the exhaust side of things (increasing pressure on the upstroke), or on turboed vehicles, closing the turbo off to restrict the flow of air into the cylinder in the first place (creating a vacuum on the intake stroke)
pretty sure you can hear the rattle of pressure release valves whenever I let the foot off the accelerator in my HDi, though cant be certain. i might look into it...
Posted : 08/11/2011 10:28 pm
Yeah I reckon that would be feasible, but would be a very expensive engine to produce. Two cylinder heads, clever gubbins and lots to go wrong, not to mention very small components with high stress loads. Easier to develop the inline 4. Which is what has happened, largely.
Give over! What would be the possible incentive to engineer a complex system of shutting off turbos or extra valves just to provide a little diesel engine with engine braking, which IT ALREADY PRODUCES IN SPADES because it is a diesel and has a compression ratio of 20:1!!! A jake brake is only neaded when holding back 40odd tonnes down extended grades and you don't want to overheat the road brakes. Your HDi Does. Not. Have. an additional engine braking system, although of you can hear rattling on the overrun I would agree that you should look into it, or chop it in quick...
Are you trolling me??? Lol
Posted : 08/11/2011 10:49 pm
You really don't get how a compressor works do you? have you ever seen one when it is off load? they turn really easily. An engine when open to the atmosphire and driven from the crank shaft squezzes the air which is then free to return to the volume it was before before its pussed out into the atmosphere. On a car you have friction and an amount of restriction from an exhust but this is the same regradless of fuel source. A compressor sucks air and the compresses this into either a system or reciver just like pumping air into a tyre. the air has no where to go and this makes it hard the higher the pressure.
my 205 gti wouldn't have had any engine braking due to my foot being on the clutch liek the teach in the driver test.
Also how come its fine for you to compare landys with different egines but not for any one else?
Posted : 09/11/2011 11:30 am
I thought the same thing when I first heard it. I wrote the editor of the GM Diesel page and this is what he wrote back:
A gas engine has more engine braking than a comparable displacement diesel because at low throttle levels a gas engine is working against a closed throttle plate. A diesel has a wide open intake manifold without a throttle plate.
Think of a diesel piston and cylinder like an air cylinder. If you press the piston up to near TDC with the valves closed, it takes a lot of pressure, right? But guess what, after rotating beyond TDC all that compressed air now pushes down on the piston to accelerate it to BDC.
A gas engine will generate about 25" of vacuum with the throttle closed, so when the piston comes up to TDC, very little pressure is there to push the piston on the down stroke. Then, when it wants to pull in a fresh charge, the engine has to pull against the vacuum. All this consumes energy and creates what is termed "compression braking".
Of course, a diesel does produce some compression braking due to mechanical losses and heat generation, but a similar displacement gas engine will always generate more "compression" braking.
taken from [url= http://www.hummerknowledgebase.com/engine/engbrake.html ]here[/url]
Posted : 09/11/2011 11:32 am
