Double oven - curre...
[Closed] Double oven - current first world problem
I'm about to get a new double oven. It's rated at 32A. The fuse (are the resettable ones called MCBs?) for that circuit is 32A. Is there anything else I need to check before placing the order? Wire size?
Posted : 23/09/2017 6:00 pm
If you have a dedicated circuit and nothing else is on it, you'll be fine.
Is it free standing or in a housing, if in a housing just check that the sizes will allow it to fit, or that you can customise your housing if need be. other than that, crack on.
Posted : 23/09/2017 6:13 pm
Thanks, it's in a housing but the dimensions look the same.
Posted : 23/09/2017 6:17 pm
