Does this flue look...
[Closed] Does this flue look right?
I've just noticed that the flue on my gas stove isn't sealed, is that ok? Should I put some flue sealant on it or is it ok to leave? Or does it require a proper check instead? We have a carbon monoxide reader in the room and it's never gone off.
Thanks
Stove
Posted : 14/02/2021 2:53 pm
Does this work?
Posted : 14/02/2021 2:57 pm
You might be surprised to learn that a lot of flues like the old Selkirk qc stuff used on atmospheric boilers is not gas tight. Yours shouldn't be anything to worry about but a bead of sealant wouldn't go amiss.
Posted : 14/02/2021 3:21 pm
 Bear
Looks like it is an open flued appliance, therefore the flue is open to the room that it is in. But yes usually the bottom connection of a flue should be sealed to the appliance, traditionally with fire cement which tends to crack after time. Try some high temp silicone.
Posted : 14/02/2021 3:29 pm
Thanks both, I’ll get it sealed.
Posted : 14/02/2021 3:40 pm
