Does this bit exist...
[Closed] Does this bit exist - plumbers/diy/hose/tap fitting
Hi
conveniently in the garage is a cold water tap, however the fitting appears to be somwwhat unique - end of tap is threaded and I can screw a 15mm copper compression nut onto it, is there such a bit that I can buy that will screw onto tap and convert to the plastic push garden hose fitting.
(*the tap design doesn't allow me to fit a piece of 15 mm copper as the 15mm copper is to big to fit inside the tape spout hole ......)
cheers
Posted : 12/01/2014 2:09 pm
Googling "threaded tap connector" gives many, many results?
Unless it's an odd size, from memory pretty much every outdoors tap I've ever seen has had a threaded connector. I don't think it's that unique.
Posted : 12/01/2014 2:14 pm
A 15mm compression fitting has a 1/2 inch bsp thread.
That is pretty standard on a tap and there are plenty of hose connectors that fit.
Posted : 12/01/2014 3:22 pm
cheers, winston - that helped a lot
having seen adverts for 1/2 and 3/4 fittings hose fitting bits I now know what that weird grey insert lying the the hose spares box is - it's a 3/4 to 1/2 adapter (never needed on any other tap I've used - so I guess the current/main size is 3/4) and by sticking it into my existing 3/4 fitting it now works perfectly - doh... as the 15mm compression fitted I was expecting to need a metric to inch sort of converter - copper to plastic
Posted : 12/01/2014 4:18 pm
