Do LEDs strobe?
[Closed] Do LEDs strobe?
Just curiosity really.
Riding in the rain, I noticed the drops of water flying off the front wheel back towards me looked they were in a strobe light, in that I could see each drop as multiple drops about 10mm apart, not one continuous moving drop.
I did wonder if it was the drops tumbling and only showing up as they were orientated a particular way, but then I got the same effect working under a vehicle wearing a head torch and watching dust fall down off the chassis.
As I understand it, any sort of diode will only work with DC, so this isn't the old record turntable 50Hz AC light bulb trick.
Do LEDs work off some sort of pulsed DC?
Posted : 03/10/2014 11:42 am
When you run an LED at different output levels you can see the frequency of the strobing change
Posted : 03/10/2014 11:45 am
All depends on how it's driven. if it just has a current control resistor in series it will glow constantly, if there is an electronic driver circuit is will vary the mark-space ratio to control power consumption, eg it is not on all of the time.
Posted : 03/10/2014 12:06 pm
 JAG
Yes they do strobe - watch slow-motion video of any car with LED lights. Usually see it best on the tail lights during some video from Top Gear.
Posted : 03/10/2014 12:11 pm
http://en.wikipedia.org/wiki/Pulse-width_modulation
Posted : 03/10/2014 12:14 pm
yeh, it's great when you're riding in rain and it looks like tracer bullets ๐Ÿ˜€
Posted : 03/10/2014 12:28 pm
or like hitting warp speed!
Posted : 03/10/2014 12:39 pm
Mine strobes, you can use it as a speedo, as it freezes the tire thread at a certain speed.
Posted : 03/10/2014 1:01 pm
No, DC driven. However, you can switch them on and off very quickly....
Posted : 03/10/2014 1:37 pm
LEDs on cars strobe as the 12v DC isn't really DC, either its generally a half (badly) rectified AC, or the DC circuit voltage contains canbus data on carrier signal which would again lead to pulsing. As the response time of an LED is so quick they get to switch on and off in between pulses.
Bike LEDs strobe at different output settings as the drivers use Pulse Width (PWM) controllers so for a low output it might turn the light on & off 70 times per second, whereas a higher output it might go to 140 times per second, full power is usually just "on" with no interference from the controller.
Posted : 03/10/2014 1:50 pm
All good LED drivers will be DC PWM.
It not only helps control the brightness much more effectively than voltage or current limiting but it is also used to reduce heat build up so even on full power your LED might be under PWM as the manufacturer has set a PWM level that gives a good brightness but keeps the heating and battery drain under control.
Posted : 03/10/2014 2:29 pm
If your bar light is shining over the knobbles on knobbly tyres you get the usual strobing effects like the wheel going round the wrong way.
Posted : 03/10/2014 2:33 pm
Oh What! You mean physics doesn't really break down at night time and I'm not really going faster than the speed of light? Its just a trick of the lights? ๐Ÿ˜ฅ
Posted : 03/10/2014 2:40 pm
Er, no. Quite a lot of poor quality LED drivers use DC PWM (along with some of those in quite expensive lights), the good ones use a current regulated DC convertor - one of those does have a PWM signal in, but it's controlling a switch mode convertor which will have a bit of variation in current as the inductor charges and discharges, but the LED doesn't switch on and off. Significantly more efficient to do that as LEDs get more efficient at lower current levels - if you use a higher current switched with PWM to achieve the same brightness you'll use more power.
Posted : 03/10/2014 2:41 pm
And the strobe effect will knack the readings on a wirelss computer. Used to get some really weird and fanciful readings on night rides, but eh best was when I caught the Aldi Bikemate computer doing 78 mph on the breadbin thanks to the LED downlighters in the kitchen.
Posted : 03/10/2014 2:42 pm
you are reading things into my post that I didn't write or imply
I am simply stating that high quality ones won't be some simple potential divider or variable resistor and will have some PWM control. Cheap ones can have it too of course as PWM circuits are not exactly expensive.
Posted : 03/10/2014 4:26 pm
You wrote DC PWM - is that not what you meant?
Posted : 03/10/2014 4:28 pm
^^ this
Posted : 03/10/2014 5:39 pm
The answer to the OP is yes, why does it need 19 posts to argue about it?
Posted : 03/10/2014 5:45 pm
Well, this is STW after all...
Posted : 03/10/2014 6:31 pm
Because the answer is actually, yes some but not all of them ๐Ÿ˜‰
Posted : 03/10/2014 6:59 pm
The little red figures on pedestrian crossing controls strobe too, if you look at them in the dark and quickly look away you get a string of little red figures trailing after each other.
Well, I do, anyway... ๐Ÿ˜€
Also, sometimes, if you put an LED flashlight down on a hard shiny surface while turned on, like a loo cistern, you get a high-pitched buzzing.
Posted : 03/10/2014 8:01 pm
My headtorches definitely strobe on lower power settings. I don't think my bike lights do though.
Posted : 03/10/2014 8:04 pm
On my Petzl head torch with three LEDs, presumably all three would be strobing simultaneously?
Posted : 04/10/2014 8:56 am
If you've got a small LED flashlight, try holding it between your teeth, it'll buzz like fury! ๐Ÿ˜€
Posted : 04/10/2014 1:18 pm
I was a bit surprised and disappointed to find that my SMART LED rear strobes even on full power
[url= https://farm6.staticflickr.com/5601/15415280076_7ecd1ec913_z.jp g" target="_blank">https://farm6.staticflickr.com/5601/15415280076_7ecd1ec913_z.jp g"/> [/img][/url][url= https://flic.kr/p/puckGY ]painting with light-1[/url] by [url= https://www.flickr.com/people/7615885@N08/ ]John Clinch[/url], on Flickr
Posted : 04/10/2014 5:40 pm
Maybe or maybe not, unlikely to strobe separately.
Or they're 3 cheap LED's (i.e. not that bright) being run directly from the battery.
Posted : 04/10/2014 5:59 pm
