Community
DIYtrackworld - flo...
[Closed] DIYtrackworld - floor level shower drain
Hello all
I've seen the strangest things sorted on here over the years, so this should be easy...
My crappy bath/shower combo has, it would seem, spent the last few years emptying 2% of it's contents in to the wall cavity, insulation, floorboards, etc. It's all out now, and I'm going to tidy up the damage and bang in a shower.
Most showers these days seem to have a very shallow/flat tray, so the drain needs to be below floor level. Not so in my build 'em quick, cheap as chips, newish build. The waste pipe sits behind a moulding above the floor. The joists are all perpendicular to the way I need the waste to go, and I'm assuming its not a great idea to cut a 2" (or whatever it is) hole in 5 or 6 joists In a row! Am I missing something or am I going to have to resign myself to a rubbish looking plinth to raise the shower up a bit?
Posted : 26/11/2012 10:42 pm
Raise the level of the floor in the bathroom by 6 inches,and run the pipes in the space, you will have to reduce the height of the door by 6 inches plus and youll need to duck before entering. ๐Ÿ˜ฏ
Posted : 26/11/2012 10:56 pm
Ha ha. Yeah I was thinking about adding another stair to the staircase, raising the whole first floor, and shortening all the doors; but I'm quite tall. ๐Ÿ˜†
Posted : 26/11/2012 10:59 pm
can you not re-jig the layout of your bathroom?
If you have ripped everything out it shouldn't take much to move some pipes.
Posted : 26/11/2012 11:05 pm
I did consider that, but I'd just be moving the problem, as the only place I could put the shower that would help; would then displace the throne. And the waste for that would be even harder to move.
Posted : 26/11/2012 11:11 pm
Does the shower have another outside wall you can take the waste pipe through ?
Posted : 26/11/2012 11:14 pm
No, but it's above the garage. Do you think it would ridiculously Heath-Robinson to have a waste pipe appearing through a garage ceiling and routing over to the wall (where the main waste is)?
Posted : 26/11/2012 11:18 pm
I wouldnt argue but i suspect your garage roof is a firewall if you hve living spce above nd thus it would not be acceptable.
Posted : 26/11/2012 11:26 pm
Fair point.
Posted : 26/11/2012 11:31 pm
You can get non shallow shower trays. Some come with optional feet and surrounds to raise them up.
Posted : 26/11/2012 11:40 pm
You will be fine running the waste into the garage.
Google "Firoblok" its a pipe wrapping for wiring/pipes passing through fire rated walls and floors/ceilings.
Posted : 26/11/2012 11:51 pm
Thanks all, much appreciated.
Posted : 27/11/2012 12:08 am
Didn't do it myself, but our shower was fitted with a slightly raised tray (about 4") that had a floor level drain. Builder bloke then ran the drain pipe along the skirting board and neatly boxed it in.
All came as a kit, so must be out there somewhere!
Posted : 27/11/2012 12:22 am
