DIY tv aerial align...
[Closed] DIY tv aerial alignment
Loathe as I am to pay anyone to do something I can do...
...is this feasible? Assuming I can get to the roof ok (there's one in the loft also but I can't see where the lead comes out).
There's a prize for the first person to mention Rod Hull. Looks like I t won it!
Posted : 01/11/2013 12:32 pm
can you see which way all the other houses aerials point or are they all in the roofs?
Posted : 01/11/2013 12:33 pm
 Mr_C
Some TVs and set top boxes give you a signal strength meter. Obviously you need someone at the other end looking at it as carrying a 46" tv up a ladder could end badly.
Posted : 01/11/2013 12:40 pm
left a bit, right a bit, now don't move - job done
Posted : 01/11/2013 12:46 pm
ive got a thingy you plug the cable into and displays the signal strength, was really handy when we lived in a poor signal area with loft aerials.
Posted : 01/11/2013 12:49 pm
Cheers, mine points in the same direction (roughly) as others (to Fife).
One of my pvrs has a signal strength meter too.
I just wondered if there were any secrets.
Posted : 01/11/2013 12:54 pm
you can get apps for smartphones which show you where the nearest transmitters are and which direction to point your aerial at.
the app I used was a bit clunky but it worked.
EDIT: it was called UK Aerial Alignment (Android)
Posted : 01/11/2013 12:55 pm
Compass and Google the bearing that's all I did but put mine in the loft as there was no need to go on the roof.
Posted : 01/11/2013 12:57 pm
Same method as Drac, just remember to keep the compass away from metal or the job takes longer ๐Ÿ˜ณ
Posted : 01/11/2013 1:00 pm
Don't take the emu with you though. These are not an asset when ladder climbing.
Posted : 01/11/2013 1:01 pm
I used my phone
This was the site I used for the bearing.
http://www.ukfree.tv/transmitters.php
Posted : 01/11/2013 1:03 pm
Sounding good Gents, thanks.
Posted : 01/11/2013 1:08 pm
