Hi
are tile drills worth it and any specific tips
- put tape on tile
- don't apply with pressure
thanks
Use a Masonary drill,
Use a slow speed.
(+ your two tricks)
Mark spot with pen, use a standard woodscrew (a nice sharp new one)and 'dink' it with a hammer on said spot. This should take a small chip off the glaze, then use an SDS bit but on drill not hammer to go through the tile, then use hammer action to drill into masonry behind. I've used diamond tipped tile bits before and they're a waste of money IMO, this was years ago mind so they might have improved since
For the sake of £3 tile drill bit and nice and steady
Go to Wickes buy tile drills - make sure hammer action is OFF - drill through tiles - marvel at the neat holes.
Seriously do not hit anything with a hammer - cracked tiles look shit forever.
Tip I used was to use masking tape to give the drill bit something to attach to, rather than just float about. Seemed to work..
yep, tile bit well worth it. keep it cool too.
Put 200 towel rails up in a new hotel when I was an apprentice using that technique, didn't crack a single tile, 1200 holes if memory serves. But if you're ham fisted give Wickes your money. And I didn't say "hit" I said "dink" which is an industry recognised technical term as any fule no.
Tile drill . In a hand drill . Use a bit of tape on the tile to avoid slipping.
What if the tiles are porcelain?
Run the drill in reverse to start it off. Then forwards with out hammer.
Never seen anyone in the trade use a tile drill.
I've installed countless bathrooms and I've never used a tile drill.
Never cracked a tile or made a mess drilling through a tile either.
Masonry bit, hammer off, push the bit against the tile slightly to mark the glaze so it won't slip, drill tile.
It's really that easy.
Diamond core bits and water cooling.
I bought a tile drill bit and it is absolutely painless.
Hammer off and slow speed.
I am completely handless amd mever cracked a tile. Well worth £3.
If you already have a masonry bit, then it was £3 wasted 😉
(If you don't, then fair enough)
I do actually use a tile drill bit, Black and Decker Piranha. they are quicker than masonry drills and make a cleaner hole, only drill the tile with them though, not the wall. Oh, and NEVER drill in the joint, you may get away with it but if anything is gonna break a tile, this is it!
Std masonary is fine though, without hammer if required. I 'mark' the tile with the tip of it 1st to stop it slipping on the glaze.
Having recently done this (two mirrors, two shelves, toiletry holder) I found the best way is:
Mark with masking tape
Use a 6mm tile bit (£4 and makes drilling the hole in exactly the right place much easier than a masonry bit)
Drill for 8 secs, then dip bit in water to lubricate, then repeat.
Avoid a diamond core bit - £14 and utterly bobbins
6mm hole through tile
Switch to 5mm bit as soon as you hit the adhesive (I used a new HSS bit as it was only going through adhesive and plasterboard)
Red plugs inserted flush with the tile
no. 6 screws
Tile bit and tape over the tile to stop slipping .FFS dont use a hammer and screw/nail to mark it
If you're working over a bath or sink put a piece of ply over the bath or put towels etc just in it as cushioning in case you get all butter fingered and drop a tool.
