DIY botherers - hel...
DIY botherers - help me with a small bodge
I've just got a new IKEA desk. For some reason, the desktop sits about 2-3mm above one of the big metal struts that you'd think would be supporting it, and I feel like this is causing the desktop to vibrate a bit when I play music (my speakers sit on the desk).
So I want to wedge a few small rubbery things in the gap to make it a bit more solid and reduce vibration. I was thinking something like these?
https://www.diy.com/departments/vitrex-wd250-plastic-5mm-tile-wedges-pack-of-250/5011204615834_BQ.prd
But they're plastic rather than rubber, so might work their way free? What would you use?
Posted : 24/02/2023 10:55 am
Some thick rubber washers might work well.
Posted : 24/02/2023 10:58 am
Isn't this what beer mats are for?
HTH ๐Ÿ™‚
And stick your speakers down with blu-tack - that's where the vibration may be coming from.
How about a few felt 'stickers' - often sold for under furniture or other items that may scratch a surface. Cheap as chips and you can stack a couple if not 'tall' enough. I've had a 'sheet' of them for a few years, and always find a use for one or two.
Posted : 24/02/2023 10:59 am
How about actual rubber? AKA pencil eraser. Cheap, readily available and easy to cut to correct thickness.
Posted : 24/02/2023 11:04 am
Being as this is a mountain bike forum, i'm going to say my go to for small amounts of rubber tends to be old inner tubes
Posted : 24/02/2023 11:26 am
Packers + blob of silicon if required
https://www.toolstation.com/broadfix-u-shims-kit/p24053
Posted : 24/02/2023 11:31 am
Thanks for the suggestions! I might have some felt pads somewhere, but I'll probably try a couple of these ideas.
I do have my speakers on stands that decouple them from the desk - a bit - although I am probably going to try beefing that up a bit too - maybe some acoustic foam, or if it comes to it, some of those ISOacoustics jobbies.
But I'm starting with the cheap stuff!
Posted : 24/02/2023 11:32 am
Maybe stick the two elements together with something that will damp vibration in both. Look up 'toffee tape' or 'snot tape' on ebay or amazon - a sort of gooey double sided adhesive that never sets (think a bit like the sticky blob that would hold free stuff on the front of magazines.
The sound damping sheets that folk use for camper conversions would work too - a square of that on the underside of the desk maybe. Vanlifers go mad seamlessly coating the the inside of the van in a glorious vain waste of time on money - ย but all thats needed is a patch of it on each panel and it just helps stop that panel from resonating
Posted : 24/02/2023 11:53 am
Make sure you have it facing down. If facing up it will send the vibrations back into the speakers and shake them to bits.
Posted : 24/02/2023 11:55 am
