DIY Advice please -...
[Closed] DIY Advice please - curtain pole bracket...
Junior has managed to pull one out of the wall whilst swinging on his curtain. Thing is, it was embedded in plaster surrounding the window frame with a plaster board rawl plug, so theres a rather large cavity.
How to fix it in again and take the weight of the (heavy, blackout) curtain & pole?
Thanks.
Posted : 30/12/2017 2:50 pm
Try a spring toggle
Posted : 30/12/2017 2:53 pm
My experience is that you need a mounting plate/board, attached in deeply, then poles attached into and even through the mounting board.
Posted : 30/12/2017 2:55 pm
I use a wooden batton secured to the wall, then poles mounted to the batton
Posted : 30/12/2017 2:57 pm
I have had the same problem and gone for the mounting board / batten solution.
Posted : 30/12/2017 3:14 pm
Baton for the win
Posted : 30/12/2017 4:06 pm
Posted : 30/12/2017 4:09 pm
Fill the hole with polyfilla, make new hole 4 inches along with whatever mounting system you choose
Posted : 30/12/2017 5:04 pm
My previous solution, which tends to end with, wait a year and repeat.
Posted : 30/12/2017 5:26 pm
Thanks so far.
Unfortunately moving the bracket isn't possible as the edge of the window surround is only 4" away from the wall. A baton may be the answer, but I have a very low level of DIY ability.
May need a handyman.
Posted : 30/12/2017 5:35 pm
You need a different mounting system then!
A baton is easy. Get a length of timber wider than the window, and screw in to the wall with plaster board plugs (in your case) in about 4-6 places. Then screw the pole to that. Makes life easy in the future when 'the boss' decides she want's new curtain poles. No wall drilling.
Posted : 30/12/2017 5:39 pm
By a house made from bricks ๐Ÿ˜€
Posted : 30/12/2017 6:55 pm
The pedant in me has to point out that it's a batten you want, not a baton that would be used to conduct an orchestra ๐Ÿ˜€
Posted : 30/12/2017 7:37 pm
I stand corrected.
Posted : 30/12/2017 8:45 pm
Ive been called a handyman previously, where do you live near.
could also be a quote headline in a tabloid paper regarding that failed and pathetic woman ruining the country at the present time.
Posted : 30/12/2017 8:58 pm
Be aware that a batten could mean your rail would protrude thus inviting the dreaded morning light.
I've resorted to a super-duper blackout eye shade that covers most of my face.
Posted : 30/12/2017 9:04 pm
We have curtains over blackout blinds for full 8) 8) 8) effect.
Posted : 30/12/2017 9:37 pm
Just paint your windows then. I can't believe that a grown adult with all the resources available to them these days can't figure out how to attach a simple piece of wood to a wall.
Posted : 30/12/2017 10:02 pm
