Now that I have my new super bean to cup coffee machine I'd like to get some more use out of it. If i have anything with caffeine in after about 5pm then I'm awake till 3 in the morning so I'm investigating decaf coffee beans. Worth having or am I wasting my time (in terms of taste i mean)? Recommendations?
Get out!
When my wife was pregnant she had a lot of decaf and the best we found was Hasbean Guatemala El Bosque. I drank it regularly out of choice and enjoyed it nearly as much as our normal beans of choice
http://www.hasbean.co.uk/products/guatemala-el-bosque-washed-co2-decaf
๐ Drac
How do they get the caffeine out? I've always wondered.
never really understood the point of drinking decoffeenated...
Its like what do they do with the alcohol they take out of alcohol free beer? I think they put it in my Skol Super ๐
Often, [url= https://en.wikipedia.org/wiki/Decaffeination#Solvents_used_in_decaffeination ]with solvents[/url].
Nothing to see here, keep scrolling.....
Think they wash it in coffee. Caffeine leaches out, coffee flavour stays in. This is based on a brief glance at something 20 years ago.
Have found the Harrogate stuff to be OK.
They then sell the caffeine for more than they sell the coffee...
Pact do really nice decaf coffee beans on a subscription service - I've been decaf for a year.
For cheaper beans, Waitrose do them as do Starbucks. There are loads of good decaf beans out there.
For removing the caffeine they use the swiss water process ( http://www.coffeereview.com/coffee-reference/coffee-categories/decaffeinated-coffee/swiss-water-process/). Definitely avoid coffee that isn't swiss water as they'll have used solvents.
Booths do an own brand swiss water decaf, which I am currently restricted to whilst healing broken bones. In reality it doesn't lose much to some of their other decent caffeinated blends.
As above, Swiss Water Decaf is the best for retaining some actual flavour IME.
The best coffee I've had is with a French Press and beans from [url= http://www.cooper.co.je/ ]Cooper & Co Coffee[/url] and that was actually a decaf! I'm not sure I'd recommend it for espresso though as it always been a bit average in comparison.
Give a go to any of the stuff from your local small batch roaster or online alternatives.
Not in that specific (Swiss Water) case, you wash the beans in 'coffee' then filter the coffee through charcoal to remove the caffine, then re-use the coffee. It's the only process that doesn't allow for the recovery of caffeine.
The other options are:
Super-critical CO2 (i.e. CO2 at such high pressure that it has the density of a liquid, but the viscosity of a gas).
Ethyl acetate.
Di-chloro Methane is used as well, but this is potentially carcinogenic. It is however viewed as 'the best' in terms of retaining coffee flavors, so still used. Especially if you're buying from some posh s****y hipster artisan coffee roasters. I'd not worry though, the FDA safe level is 10ppm, after steaming it's nearer 1ppm, it then spends 15minutes in the roaster at 200C (boiling point of DCM is about 35C), then you make coffee with it at 100C, there isn't a notable amount in your coffee.
CO2 is used via the indirect process (CO2 is mixed with the water like the charcoal is in the Swiss process), the other two can either be done this way (so the beans only ever contact trace amounts of solvent anyway) or by directly soaking the beans in the solvent.
Ohh and 'naturally decaffeinated' usually means washed in ethyl acetate, why? Because ethyl acetate is naturally occurring in fruit. The fact that the stuff used to extract caffeine is likely from an oil refinery is an inconvenient truth.
DeCaf coffee????
Is that a bit like going with a prostitute for a cuddle ๐
Don't knock it till you've tried it. I get good money for 'Snuggle time'
I thought the caffeine was removed by being rolled on the naked thighs of ex coal minors
Waitrose do a nice one with a blue label, forget it's name. Monsoon Malabar perhaps?
The Pact decaf is nice, MrsMomo also bought me a big bag of Lavazza decaf espresso roast beans for christmas which were good.
Pact decaf is really quite good
Goes well in a mocha before bed
Peru, it was.
Ozone coffee.
Thanks for the info on decaffeinating, confirms my belief in keeping it in.
St Martins in Leicester sell kick-ass decaf Beans
I drink decaf in the afternoons
I don't really get all the beating of chests when you tell people this. I agree it's not as it was originally intended, but so what? Diet Coke, hybrid cars, e bikes, margarine etc
If it works for you crack on
I'm not a coffee snob so don't mind standard decaf grounds from Taylor's etc
Will have to pop into Leicester at the weekend and give them a try.
