Dear hive mind, any...
[Closed] Dear hive mind, anyone know how to fix tellies?
Hi Folks
My old Sharp LCD has developed a fault
See pics, basically the bottom 10% of the screen is a repeat of the top.
So anyone know anything about LCD panels
Is it ****ed?
Ta
Rich
Posted : 17/11/2012 1:21 pm
can you not just lift the tv a couple of inches?
no, you are right. i know bugger all about televisions.
Posted : 17/11/2012 1:33 pm
Yeah easy fix that, gaffer tape across bottom 2 inch should sort it
Guffaw :-))
Posted : 17/11/2012 1:48 pm
kick it. what i would do, it would surprise ye how many times a good wallop can sound out electronic good! ๐Ÿ˜†
Posted : 17/11/2012 2:12 pm
It doesn't like your tv programme choice ๐Ÿ™‚
Looks to me like part of the signal decoding is going wrong. Don't know enough to fix it, but I suspect it'd be cheaper to replace whole boards inside than track down the error. Which may or may not be more expensive than buying a new tv.
Posted : 17/11/2012 2:14 pm
what happens when you change the aspect ratio ?
Posted : 17/11/2012 2:16 pm
 dobo
we did work on crts when i learnt digital electronics and fixed some faults, hmm that pic looks familiar.
i actualy dont even know if crt tech is same as lcd for the frame side of things but on crt they used to be a frame chip that commonly caused issues like in the pic and sometimes some capacitors around it used to go out of tollerance and were visably defective. sometimes it was just the solder joints around the capacitors causing the issues.
i would do exactly what seo says and hit it and see if the picture changes or momentarily returns, if it does, its most likley a dry solder joint somehwere.
not much help i guess but be warned that tvs can hold charges and give you a decent shock even when powered off, when on they can kill you.
Posted : 17/11/2012 2:27 pm
AV FORUMS
Posted : 17/11/2012 2:51 pm
Back in the old days, a dodgy vertical hold would have caused something like that.
Of course, LCDs don't have any way to adjust this.
Posted : 17/11/2012 4:25 pm
Just get hold of 2x two inch high strips of mirror, the same width as your screen. Fix one to the bottom, at a 45 degree angle to the screen, and one just above the screen, at a 45 degree angle towards yourself. Instant periscope, problem solved!
Posted : 17/11/2012 4:46 pm
Make sure the settings in the AV Setup menu are set to auto. It may be trying to display SD in HD mode or something like that.
Posted : 17/11/2012 4:57 pm
Switch it off and back on again , with conviction.
IGMC
Posted : 17/11/2012 5:04 pm
The only thing worth trying IMO.
Posted : 17/11/2012 5:09 pm
 Taff
My mate had something similar on his. There was a circuit board connection on the inside that broke so when it got hot the picture went similar. Being a crack handed at DIY he thought it easier to buy a fan to cool the tv down - job done!
Posted : 17/11/2012 5:16 pm
My [b]old[/b] Sharp LCD has developed a fault
Mend it with a new one?
Posted : 17/11/2012 7:54 pm
Cheers for the answers.
To be fair I've already mended it with a new Samsung ๐Ÿ™‚
Just wondered if anyone knew if it was economical to fix before it goes to the recycling centre. It was a good TV, shame to bin it.
Posted : 17/11/2012 9:41 pm
smash the lcd, get the missus pissed and make her think that someone has spiked her drink with lsd.
Posted : 17/11/2012 9:45 pm
There's an LCD / LSD joke in there somewhere.
Posted : 17/11/2012 9:47 pm
