Dead Humax
[Closed] Dead Humax
Hi,
I have a 3 year old Humax 9200T PVR that doesn't want to work - it starts then freezes after 10 secs or so - I've done the usual reboot etc.....
Anyone else experienced similar? Is it a new box?
I can't live without my Humax - the grief my daughter is giving because she can't pause the TV!!!!! 😀 😀
Cheers,
Posted : 02/01/2009 8:40 pm
 ton
satellite or aerial.
Posted : 02/01/2009 8:41 pm
Aerial
(wouldn't be 3 years old if satellite?)
Posted : 02/01/2009 8:50 pm
I've had my Topfield go the same way. It's either a hard disk issue or the PSU is not giving a decent 5v signal due to some capacitors failing over time. I know a Toppy isn't a Humax but it could well be disk related. Is there any clicking or unusual sounds coming from the box on startup?
Posted : 02/01/2009 8:54 pm
 ton
we have been selling humax satellite boxes for 8 yrs.
start with connections on the box, check cable for splits, has your aerial moved.
and i can sell you a new aerial one or a satellite with pvr if you need one.
Posted : 02/01/2009 8:55 pm
Why would cables affect the boot process 10 seconds in though? It's more likely that a component is failing during POST or when first accessed by the firmware.
Posted : 02/01/2009 9:13 pm
ton - You doing the Humax HD Freesat PVR? If so I might have a sale for you (assuming my old man hasn't bought his already)
Posted : 02/01/2009 9:14 pm
 ton
no one mention boot process
quote plant...it starts then freezes after 10 secs or so
which on most av equipment means loss of signal strength.
Posted : 02/01/2009 9:15 pm
[i]I can't live without my Humax[/i]
Can't help with issue but got to agree they are fantastic and a total bargain; think we paid about £120 for our Humax 8000T about 3 years ago.
Posted : 02/01/2009 9:16 pm
 ton
atlaz, we are mate.
waiting list at the mo. £219 trade i think. you trade????
Posted : 02/01/2009 9:17 pm
Unfortunately not. I think we might have a ltd company floating around somewhere though.
Posted : 02/01/2009 9:21 pm
 ton
should be ok then.
Posted : 02/01/2009 9:23 pm
 AT
I think you have got the wrong forum. Try here [url= http://www.hummy.org.uk/forums/ ]Humax Forum.[/url]
Posted : 02/01/2009 9:59 pm
hummy forum the way forward.
I had an issue recently and was fixed by following the instructions here - not sure if it is the same issue though
[url= http://www.hummy.org.uk/forums/showthread.php?t=4215 ]huumy.org[/url]
good luck
Posted : 02/01/2009 10:21 pm
I can't see it's cables and the TV works fine through a normal freeview box, so I'm assuming it's the Humax failing on early start operation. No noises at all, just stops and wonm't respond to any buttons on the front - even the standby - have to use the switrch on the back!
Will go see Humax forum (didn't realise there was one).
Ta,
Posted : 02/01/2009 10:41 pm
That Humax Forum was the answer - take out the aerial, fire iit up, reset to default then put the aerial back. Perfect!
Thanks,
Posted : 03/01/2009 1:41 am
Arse - wish I had seen that... mine did the exact same thing you are describing a couple of months back - decided to replace it with a Sony hard disk/dvd recorder. Not a bad choice mind, but I did loose the second tuner option.
Kind of thinking of buying a second telly sometime anyway, so will follow the instructions and fire the Humax into that probably.
Posted : 03/01/2009 2:10 am
Rob,
Don't know I could live without the flexibility of two tuners and pause TV - is it any wonder I'm a couch potato!
Posted : 03/01/2009 11:08 am
