Cruise Control - op...
[Closed] Cruise Control - opinion & little help as mines stopped working A4
5 Users
Like it or lothe it, I quite like it, but with the current amount of traffic on the roads it's not used very often. However I tend to use it on long distance, early mornings or late nights - but definatly anticipate using it when heading to the Alps this year.
However, it seems to have stopped working? Any ideas. It's an A4 2.0 tdi.
cheers
Posted : 02/05/2011 3:48 pm
Not on an Audi but my Honda developed a fault with a sticky brake switch which stopped me engaging the cruise. Worth a check?
Posted : 02/05/2011 3:54 pm
The slider knob on the stalk is slid too far to the right in the off position :p
Posted : 02/05/2011 3:57 pm
As Bregante says, there are probably switches on the brake and clutch pedals (to disconnect cruise if brake or clutch pedals pressed); if they're not adjusted correctly, they won't let you engage it. Worth a try?
Posted : 02/05/2011 4:03 pm
Check your brake lights. Really common problem on VAG cars. It's a 5 minute job to replace the switch.
Posted : 02/05/2011 4:35 pm
yes the rear break like warning keeps tripping - intermittently. hmmm
Posted : 02/05/2011 10:37 pm
