Crappy VW design......
[Closed] Crappy VW design....
31 Users
So one of the boot strut mounting's on the Touran has fallen off.
Much pulling off of interior panels, then inner wheel arch lining reveals that to bolt it back on is impossible.
It is a 'double skin' area of body work it seems - you could reach up from the light mounting area if you had a 50cm long spanner and the kiddy diameter arms.
Pile of pish.
Posted : 09/12/2012 9:49 pm
isn't there a rule of manufacturers now that says you cant fettle your own car cos our dealers need to make £50 an hour for 10 mins work?
EDIT: I have a new VW
Posted : 09/12/2012 9:51 pm
You didnt need to give a description of fault, the title sums up VW!!
(i also have a new vw)
Posted : 09/12/2012 9:59 pm
I have an old T reg Bora and when it's solid it's solid.....when something starts to rattle, it's like opening a "pass the parcel" parcel trying to get near anything. VW seems to add something then add another 3 layers for good measure
Problem with this wagon is it seems to rattle more than it should....
We do high miles (05 on 109K), BUT, it just is not as well built as you might expect.
The 03 / 85k Toyota we own has had nowt but tyres, service and a set of brake discs. And it is not like it gets an easier life...
[url= http://farm9.staticflickr.com/8319/8060587555_47461ef713_b.jp g" target="_blank">http://farm9.staticflickr.com/8319/8060587555_47461ef713_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/matt_outandabout/8060587555/ ]Canoe in a Yaris....[/url] by [url= http://www.flickr.com/people/matt_outandabout/ ]matt_outandabout[/url], on Flickr
Posted : 09/12/2012 10:13 pm
Looking at that Yaris, I'm baffled as to how [s]you managed to break a boot strut[/s] a boot strut spontaneously broke off on your Touran. 🙂
Posted : 09/12/2012 10:15 pm
That sir is a great photo!
Got 32k on a 14 month old passat and its starting to rattle in places around the dashboard and the boot area (estate). Just pleased its a company motor and not really mine to worry about cos I would hate to have to try and take things to bits to fix on a budget
Posted : 09/12/2012 10:18 pm
If it was the Yaris, I could understand 😉 😕
Posted : 09/12/2012 10:19 pm
Time to buy that van....
Posted : 09/12/2012 10:20 pm
I bluddy well know. mrs_oab has been on a journey to agree that we should get one asap while I can part ex the Touran to a [s]stealer[/s] dealer.
Posted : 09/12/2012 10:22 pm
Ah!! buying a van, now thats something that I will be doing. Just not sure when, it will be my gateway to that life/work balance thing i heard about once. That reminds me I havent been stalking the T4 forum for a while to get the jealous juices flowing
Posted : 09/12/2012 10:27 pm
Bolt the strut to something else then attach this to the car with some thick self tapers. It'll work, you won't see it and you get to keep your money.
Posted : 09/12/2012 10:28 pm
Rivnut. Sorted. And don't use self tappers. Ugh.
Posted : 09/12/2012 10:38 pm
Yah, rivnut or if it's a smallish hole, tap it.
Having said that I reckon there'll be a way in, you've just not found it, but it could mean dismantling the entire car.
Posted : 09/12/2012 10:42 pm
My Touran is being replaced by a Kia Sorrento 😯
Not sure if this is a good idea, my Touran has been ace 😆
Posted : 10/12/2012 12:09 am
I had a similar experience with my 04 Polo that required you to unbolt bits of the engine in order to change one of the headlamp bulbs.
The main irony of that being that in Germany you're legally obliged to carry spare bulbs in case one blows when you're out.
Posted : 10/12/2012 12:18 am
If the Kia is anything like my Hyundai it's a great idea, no rattles, no problem, just works
Have had Fords (Escort, Mondeo, Focus), VW's (Golf Bora Passat) and BMW's (1 series) before, the little Korean car is far better built than them all
Blimey, I love our touran. It's just so boring it's perfect for what we want. Don't know what vintage the op's is but ours is 53 and seems to be reasonably well bolted together. Plus being that age means I'm happy to bash it to fix it..........
Posted : 10/12/2012 6:38 am
Yep rattling VW Passat here too only 10 weeks old but rattling from the dash it's Driving me nuts!! On the plus side its a Co car so it's going in ASAP!!!
Posted : 10/12/2012 6:43 am
And it will come straight out again.
"They all do that, sir"
Posted : 10/12/2012 7:17 am
This reminds me of my wife's old Micra. To change the headlight bulbs you needed to take the headlight out, to take the headlight out you needed to take the front bumper off. To change the spark plugs you needed to remove the [b]whole[/b] air intake assembly and then get an 18" extension bar!
Posted : 10/12/2012 7:37 am
Yes, yet another rattling dash on a Passat. Mines 8 1/2 months old and done 21,000 miles and was noted on the last service. Dealer said "couldn't find anything, but if I book it in for an overnight stay, they would take another look". They all must be stone deaf, it does it all the time.
It also says "check deadlock, see owners manual" on the dash when you turn the motor off, which I did and the manual doesn't mention this. Spoke with the dealer who replied, "they all do that sir".
Posted : 10/12/2012 7:40 am
Chainslapp, "new" passat picked up Saturday noticed the same message. According to VW forum. It's because one push lock activates the deadlocks, so if you leave someone in the car (child i would think) deactivate the alarm but lock the doors they can't get out at all because the deadlocks are activated. It used to be that you needed to double press the lock button to do this.
Although to me it reads as an error message
Posted : 10/12/2012 8:57 am
I read it the same as well, as an error message. Dealer says "they all do that sir"....... Very frustrating!!!!
Posted : 10/12/2012 9:12 am
Possible that the setting can be used to remove this message but setting it for two press deadlock.
Posted : 10/12/2012 9:18 am
Will look at the settings and see if it makes a difference.
Posted : 10/12/2012 9:57 am
Same here on our '61 Golf. Although it's there I don't notice it now but would like to fix it if possible.
Posted : 10/12/2012 10:03 am
My Passat is 6 years old, 93k miles. Dash is creaky but not rattly.
Posted : 10/12/2012 11:04 am
The dash rattle appears to be the plastic cover over the speedo and mfd thing, I've had it into the garage and they removed it and put a felt insert so soften the noise. Lasted a week.
I've got a bit off a business card jammed in there at present, not making much difference.
Posted : 10/12/2012 12:31 pm
Ah! VW 🙂
Reminds me of the time I took the starter off Mrs ADH's ancient Golf so see if I could free it up:
Unbolted starter ... engine drops ...
Had to get the jack the damn engine back into place. Why use two bolts when one will do eh VW?
Posted : 10/12/2012 12:37 pm
05, and yes it is a very practical and useful (if boring) car for what we need (3 kids+bikes, canoes, kit etc).
Just not brilliantly put together IMO>
Posted : 10/12/2012 1:29 pm
Another Passat here and the dash does rattle but only when first thing when it's cold outside, once it's warm in the car it stops, very odd, previous Touran did the same thing. Anyone got a broomstick they can lend the OP? 🙂
Posted : 10/12/2012 1:40 pm
you dont know how lucky you are
1 word
alfa
actually sorry also include another word
mercedes
Posted : 10/12/2012 2:06 pm
meh, broomstick looks like a permanent feature of our car.
Managed to get a proper response from VW UK today - the only way to fix this one bolt is to peel off the whole rear 3/4 panel of the car, and then re-fit and re-spray.
Anyone know the laws on 'fit for purpose'? Seems a design that prevents any replacement of a simple (99p) part....
Posted : 02/04/2013 1:20 pm
its got 110k on the clock .
id just rivinut it and be done.
Posted : 02/04/2013 2:24 pm
Trail_rat +1
Put in a rivnut.
Posted : 02/04/2013 2:55 pm
alfa
on my third here 🙂
When I took my first in for another fault to be fixed there was a guy with a 2.5L 156 just pulling in.
I asked him how many faults he had had, he listed just about every fault it was possible to have.
then he said it was a lease car and the lease was nearly up, and he was going to buy it !
that was my first 156, the second was super solid and I gave it away when it got old to someone who is cherishing it.
now I have GT which was about 6 years old when I bought it, first service bill was large.
had a fault where the electric windows went funny - had it fixed but now the windows, which dip down a little when you open the door, now do random amounts of dip on each side 🙂
probably get another one though.
think one of the rules is not to buy a model within 4 or 5 years of its release.
Posted : 02/04/2013 3:14 pm
 Muke
VW Lupo door hinges 👿
Posted : 02/04/2013 4:03 pm
Ha! Ford Puma front bulb replacement; about ¾ hr, undoing four large Torx bolts, removing grill, undoing bolts holding headlamp unit in place, remove drain pipes, wiggle unit around until it finally comes loose, take off wiring, remove back half of headlamp unit, exposing bulbs, remove appropriate bulb, reverse process...
Comes under roadside repair in handbook... 😯
Posted : 02/04/2013 5:38 pm
Rather than a rivit nut - if you can get your Touran in a vice you could friction drill it 🙂
Posted : 02/04/2013 9:23 pm
Only vaguely related (but this is STW, so whatever), but has anyone tried one of those 4x4 Passats yet?
Posted : 02/04/2013 10:13 pm
vaguley related, I drive a 4x4 octavia most days, I'm assuming (perhaps wrongly) that it will be similar running gear?
Posted : 02/04/2013 10:38 pm
