Volvo coolant level...
Volvo coolant levels, hot Vs cold?
Got in the car today after 3 hours driving in pouring rain yesterday and an alarm for coolant level popped up (nothing yesterday). Car is parked on a steep slope so had to move it.
Drove for 5 mins to get fuel & coolant at the garage. Looked at the level and it was lower than the mark by 1/2" or so. When I went to fill the reservoir there was a a hiss of pressure release and the level moved back up to in-between the two marks (high/low) perfectly. Garage concrete is flat.
Coolant was warm but not hot, looks clear and same pink as always.ย  I checked the oil and it was hot but no cream.
Timing, fan, water pump & pulley was changed about 7 months ago (7500 miles).
In thought coolant expanded when hot? Is a hose bulging somewhere under pressure or do I have to worry about something else?
Thanks in advance.
Posted : 24/07/2023 9:05 pm
 mc
Top it up a bit and keep an eye on it.
It could just be the slope was enough to trigger the sensor, so I wouldn't be concerned unless you're regularly having to top it up.
Posted : 24/07/2023 9:16 pm
Which engine?
Posted : 24/07/2023 9:17 pm
Hdi 1.6 engine, 218k miles, been running perfectly so far.
Posted : 24/07/2023 9:24 pm
Uh, dunno - that's the PSA/Ford engine, it's done well to get to 218k miles.
Probably ask on the Berlingo forum.
Posted : 24/07/2023 10:01 pm
Sounds like some air in the system. You'll want to bleed it properly and top it up.
Posted : 24/07/2023 10:12 pm
